where does makeMKV save its prefs?
skypickle
Post by skypickle »
I changed something in the advanced section of the prefs and now I get this error:
Profile parsing error: Invalid token '-sel:-sel:all'
So I want to reset my prefs to default. I uninstalled and reinstalled makeMKV but it came back with the same error. I found the xml file in the app dir and the profile settings for Default are:
app_DefaultSelectionString="-sel:all,+sel:(favlang|nolang|single),-sel:(havemulti|havecore),-sel:mvcvideo,=100:all,-10:favlang"
So what did I do to upset makeMKV?
Re: where does makeMKV save its prefs?
Varies with the operating system.
Windows stores them in the registry, at the key HKEY_CURRENT_USER\Software\MakeMKV
But user-modified profile XML files should be stored in the MakeMKV data directory, which is set in Preferences->General.
And the profile in use contains the "real" default selection string. But, it won't be selectable if there is a parsing error in the file.
A_Man_Eating_Duck
Post by A_Man_Eating_Duck »
There any way of stopping the user-modded profile from being deleted when you upgrade MakeMKV?
Woodstock wrote:But user-modified profile XML files should be stored in the MakeMKV data directory, which is set in Preferences->General.
During the install, nothing is touched in the MakeMKV data directory. Anything in the program directory... Well, that's considered fair game.
Once I learned this, I stopped having to back up and restore my profiles. The default ones that come with MakeMKV can stay in the program directory, because they get "tweaked" every so often. But copy them to the data directory before editing them and making them "your own".
