MakeMKV Stops Halfway Through
dpillow
#1 Post by dpillow » Fri Jun 10, 2016 7:53 pm
Each time I att5empt to burn a BD disk the program stops halfway through the process. I know this info is vague but I will provide more if I know what to get.
Re: MakeMKV Stops Halfway Through
#2 Post by Woodstock » Fri Jun 10, 2016 8:00 pm
Turn on debugging if you haven't already... The log will help. FAQ in signature has more information.
dpillow
#3 Post by dpillow » Fri Jun 10, 2016 8:14 pm
Woodstock wrote:Turn on debugging if you haven't already... The log will help. FAQ in signature has more information.
Here is the message that shows up
MakeMKV v1.9.10 win(x64-release) started
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-ROM PLEXTOR BDDVDR PX-B320SA 1.05' at offset '21728917504'
#4 Post by Woodstock » Fri Jun 10, 2016 8:52 pm
That's the drive saying it can't read the disk at that point. If it was reading fine up to that point, start with cleaning the disk.
dpillow
#5 Post by dpillow » Thu Jun 16, 2016 1:33 pm
Success! I have resolved the issue. Sometimes you can't see the trees for the forest.
The disk was coated with some kind of junk. It took several cleaning attempts but it finally worked. Thank all for your help.
