How to correct a playlist on a bluray with "obfuscation" ?
thewozz
Post by thewozz »
Hi people, glad to be here with you today.
i have a little problem like other people with "playlist obfuscation".
I know how find the right playlist no real problem with that.
My problem is to find the playlist used on the bluray to replace it with the correct one.
My actual problem is with "GODS OF EGYPT 2D VERSION". I've found the correct playlist but how to locate the playlist normaly used when reading the bluray ?
using the "process monitor" method is real mess. so ?
thanks for your help
MrVideo
Re: How to correct a playlist on a bluray with "obfuscation"
Post by MrVideo »
Go to the Gods of Egypt thread.
gereral1
Post by gereral1 »
thewozz wrote:Hi people, glad to be here with you today.
My playlist obsufucation video also has 2 more videos REVEALING the disk mpls using byte matching. Go give it a try. Works like a charm.....
Note: When powerdvd cashes a hidden mpls file go find it and use these methods to reveal the disk mpls. Remember I'm only for movie extraction..... The rest can go in the trash.
thewozz
Post by thewozz »
Can someone delete or close this thread ? thanks a lot and sorry for the convenience
taylorwmj
Post by taylorwmj »
thewozz wrote:using the "process monitor" method is real mess. so ?
Well you asked how to figure out which playlist is playing. This is the only true 100% accurate way to handle it. It's also quite simple and not really a mess. Always gives the absolutely correct .mpls file.
