The Assassin - won't rip
IanForber
Post by IanForber »
Any ideas how to rip The Assassin? I tried yesterday and got the disc to open but there was no audio (I've checked in VLC and there is no audio track) - video track is OK though.
Tried to re-do today and it won't even open the disc - all I get is the following error report. I am using a Mac with external Samsung BD reader.
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:d7798fa74f79e257:TSSTcorp BDDVDW SE-506CB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0ACABB26489DAB9C5362835A1B8FFDAAE48 to device 'IoKit:IOBDServices:d7798fa74f79e257:TSSTcorp BDDVDW SE-506CB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0BAE65B885D3E6188CF2EF0A12951A6BE6F to device 'IoKit:IOBDServices:d7798fa74f79e257:TSSTcorp BDDVDW SE-506CB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0DC90F5A1642A6A687ED0114C614002C6C0 to device 'IoKit:IOBDServices:d7798fa74f79e257:TSSTcorp BDDVDW SE-506CB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0932106DA16A6237671609455C8858E0288 to device 'IoKit:IOBDServices:d7798fa74f79e257:TSSTcorp BDDVDW SE-506CB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..028EC145F973833BD3BCE9FAD32F6E05AEE to device 'IoKit:IOBDServices:d7798fa74f79e257:TSSTcorp BDDVDW SE-506CB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..04DDF1FEF24B8612BA989D3042B95B2A521 to device 'IoKit:IOBDServices:d7798fa74f79e257:TSSTcorp BDDVDW SE-506CB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:d7798fa74f79e257:TSSTcorp BDDVDW SE-506CB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0A7D8540D7D7D56FB6D24B87ADE41E5B192 to device 'IoKit:IOBDServices:d7798fa74f79e257:TSSTcorp BDDVDW SE-506CB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..002729C9A1870F79E34F9BB854E8E7DC9DF to device 'IoKit:IOBDServices:d7798fa74f79e257:TSSTcorp BDDVDW SE-506CB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..01455D098B8FABA165DA6D96EB82ABDBB81 to device 'IoKit:IOBDServices:d7798fa74f79e257:TSSTcorp BDDVDW SE-506CB TS01'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..022FF429FC7A2F3782DDD384FDFDF588C02 to device 'IoKit:IOBDServices:d7798fa74f79e257:TSSTcorp BDDVDW SE-506CB TS01'
Highest AACS version is v57 , MKB saved as /Users/ianforber/.MakeMKV/MKB_v57_THE_ASSASSIN.tgz
Any ideas?
Ian
Re: The Assassin - won't rip
The SCSI errors are something MakeMKV can't work around. The drive says it can't read the disk, for whatever reason.
First step I would do is unplugging the drive, let OS X recognize that it is gone, then plugging it back in. This resets both the drive and OS X's connection to it.
I would also check the disk itself, particularly in the hub area, for dirt, fingerprints, cracks, separations, or other imperfections. This is the part of the disk that is read when loading the disk, and defects here will make the whole disk unreadable.
IanForber
Post by IanForber »
Thanks - tried it and it reset MakeMKV and allowed me to rip another version of The Assassin. Same problem though. Video rips fine but no sign of the audio track.
Anyone any ideas?
Ian
Check that your player supports the audio encoding; MakeMKV just copies it from the BD or DVD into the MKV file, unless you've asked it to change the audio (that's under advanced features, not normally done).
In VLC, did you check to see if there were multiple audio streams? Occasionally, VLC will decide to pass a particular CODEC through to the display device. That can be either wonderful, or frustrating. :)
