They may have assumed you were using Region 1 (USA) discs.mikeinessex wrote:ok ill try c if it works. in middle of rippin aliens 3 so do it after that. someone else ealier on this thread said all the ones i stated have been ripped an work. well if so y not for me lol
avq files download. how?
Krobar
Re: avq files download. how?
setarip_old
Calculated BUP offset does not match one in IFO header.
This sure looks like a DVD that was pre-ripped with DVDFab or similar. Was it?
mikeinessex
yes i have previously tried them with the dvds. but i kept gettin a black border round the end result so i uninstalled them and searched for other software. i have ripped with makemkv with dvds i previously used on other software and it worked.
Krobar
If the DVD is a Letterbox type or anamorphic with an aspect ration of 1.85:1 or higher then the black borders at the top and bottom are normal.mikeinessex wrote:yes i have previously tried them with the dvds. but i kept gettin a black border round the end result so i uninstalled them and searched for other software. i have ripped with makemkv with dvds i previously used on other software and it worked.
mikeinessex
yh i was getting black boxs to the sides aswell so in full screen it was like the film was a box in a black screen so to say
Krobar
I think that is probably an issue with your player software or codecs. I use Windows Media Player and the CCCP codec pack and have not had any aspect ratio or scaling issues.mikeinessex wrote:yh i was getting black boxs to the sides aswell so in full screen it was like the film was a box in a black screen so to say
setarip_old
I have no idea what you are trying to say!yes i have previously tried them with the dvds. but i kept gettin a black border round the end result so i uninstalled them and searched for other software. i have ripped with makemkv with dvds i previously used on other software and it worked.
Is the log you've posted the result of using ONLY MakeMKV with an ORIGINAL, COMMERCIAL DVD, or is it the result of using MakeMKV with a ripped COPY (either on disc or on hard drive) made using DVDFab or similar as the source?
mikeinessex
yh i dont no what is up with my media player cause i have that codec pack an i have dwnloaded a few others before an none of em seem to work with media player 10 they only work if im using classic but even on divx an vlc i was gettin black border
mikeinessex
oh its a commercial dvd i bought from the shop which im trying to rip. uk dvdsetarip_old wrote:I have no idea what you are trying to say!yes i have previously tried them with the dvds. but i kept gettin a black border round the end result so i uninstalled them and searched for other software. i have ripped with makemkv with dvds i previously used on other software and it worked.
mikeinessex
so what is forcing cell trim for?
setarip_old
@mikeinessex
I would very much appreciate it if you would respond SPECIFICALLY to my last post.
(And since you have two people trying to help you, ADDRESS your responses to the person you are answering)
**EDIT**Since you seem to keep going off on new tangents, I'll stop posting to this thread.
Bye...
Bye...
Krobar
I'm no expert but I think MakeMKV has two diferent methods for dealing with protected DVD structure. Trim is plan B.mikeinessex wrote:so what is forcing cell trim for?
mikeinessex
SETARIP_OLD
I thought by quoting you it was a reply to you?
im new to all this give me a break lol
mikeinessex
what am i doing wrong that satarip is getting moody about?
mikeinessex
i was mentioning forcing cells cause krobar mentioned it to me. i would assume he would know i was talking to him and that you would know it was something we have not speaken about?
