Gods of Egypt - about 100 titles showing
DJRumpy
Post by DJRumpy » Tue May 31, 2016 6:36 pm
Anyone have any luck with Gods of Egypt yet? Not finding much on Google.
Meister_Proper
Re: Gods of Egypt - about 100 titles showing
Post by Meister_Proper » Tue May 31, 2016 7:45 pm
You may use 00434.mpls or 00695.mpls, they are identical. Tested myself.
DJRumpy
Post by DJRumpy » Tue May 31, 2016 8:33 pm
Excellent and thank you. Ripping 434 now. Mine is UPN 3139824481
foamie
Post by foamie » Wed Jun 01, 2016 4:00 am
Any way you could list out the segment map please?
tlnielsen5
Post by tlnielsen5 » Wed Jun 01, 2016 6:23 am
I have filename 00320.mpls as the correct one. With the following segment map: 510, 519, 512, 515, 516, 509, 504, 511, 505, 502, 518, 514, 507, 503, 501.
Segments 503=506=508=513 AND 511=517.
My disc is the Blu-Ray & Digital HD, UPC 031398244813.
Hope that helps.
tca32123
Post by tca32123 » Wed Jun 01, 2016 11:42 am
any suggestions on the redbox version? the segment mapping is different and those MPLS don't exist on the redbox version.
much thanks!
DJRumpy
Post by DJRumpy » Wed Jun 01, 2016 12:25 pm
EDIT: 434 is not correct. Watching 320 now to verify
Here's my map for 434 (UPN 3139824481) (purchased from Target)
NOTE: I haven't verified this yet, but will watch it later to confirm if the rip is good. The 434 was referenced above. I just have to verify it's good for this UPN.
Title information
Name: Gods of Egypt (English)
Source file name: 00434.mpls
Duration: 2:08:11
Chapters count: 17
Segment count: 18
Segment map: 510,513,519,512,515,516,506,509,504,511,505,502,518,514,508,507,503,501
File name: Gods_of_Egypt_t107.mkv
foamie
Post by foamie » Wed Jun 01, 2016 12:29 pm
I think the redbox version is 519,502,508,520,510,506,509,512,504,513,517,501,514,516,511,518,515,505,507,503. I pieced together the movie after watching it and then playing each m2ts file in order that I remember from the movie.
898.mpls matches this mapping.
tca32123
Post by tca32123 » Wed Jun 01, 2016 1:18 pm
sweet -- thank you very much
gamecaptor
Post by gamecaptor » Wed Jun 01, 2016 2:19 pm
RedFox AnyDVD says it's 898 for the rental version.
Total size: 11460032 sectors (22382 MBytes)
Video Blu-ray label: GODS_OF_EGYPT
Media is AACS protected!
Drive supports bus encryption!
Disc wants bus encryption!
AACS MKB version 60
Removed AACS copy protection!
Note: automatic detection of region code not possible with this disc.
Blu-ray Java signatures fixed!
BD-Live deactivated!
Sony structural BD-J protection removed!
Java BD protection good playlists: 898
lawndart
Post by lawndart » Wed Jun 01, 2016 2:55 pm
This one worked for me- same UPC code. Thanks!
tlnielsen5 wrote:I have filename 00320.mpls as the correct one. With the following segment map: 510, 519, 512, 515, 516, 509, 504, 511, 505, 502, 518, 514, 507, 503, 501.
Hope that helps.
DJRumpy
Post by DJRumpy » Wed Jun 01, 2016 3:10 pm
Have you had a chance to verify your yet? I haven't verified 434 yet, so may rip 320 just to cover my bases.
lawndart wrote:This one worked for me- same UPC code. Thanks!
Hope that helps.
MrVideo
Post by MrVideo » Wed Jun 01, 2016 9:26 pm
For this disc, players want to play 510.mpls. So, when dealing with this, copying 320 to 510 will fix that.
GRUPPR
Post by GRUPPR » Wed Jun 01, 2016 10:16 pm
Netflix BD info:
Title information
Name: Gods of Egypt (2016) (English)
Source file name: 00898.mpls
Duration: 2:07:02
Chapters count: 16
Segment count: 20
Segment map: 519,502,508,520,510,506,509,512,504,513,517,501,514,516,511,518,515,505,507,503
File name: Gods_of_Egypt_(2016)_t363.mkv
Visually checked segment sequence.
DJRumpy
Post by DJRumpy » Wed Jun 01, 2016 11:28 pm
434 is definitely not it. End scene injected into the stream very early on, within the first 4 minutes. Updated my post above with that info.
