Beta key expired
Norman
Beta key expired
Post by Norman »
While the page with the new key says it's good until the end of May 2016, it appears to have already expired on 5/30. I can't find a new key, is one available?
Re: Beta key expired
The new key will be placed in that same message, once Mike generates it. So that's where to check.
In the mean time, you can set your system DATE back to, say, 2016-05-25, start MakeMKV, then put the current date back in after it is running.
The alternative is to buy a non-expiring key, and not worry about dates anymore.
