Deadpool output issue.
thattechwizard
Post by thattechwizard »
https://drive.google.com/open?id=0B7atz ... zFURWhQN2c
Got a surprise when trying to do the Deadpool movie in MakeMKV.
A test of one of the smaller titles came up perfectly, so I can eliminate the speed of my HDD as the issue.
Retrying now, while outputting the source to an SSD. Maybe that'll help.
Anyone need any info (model of drive, system specs), just ask.
Re: Deadpool output issue.
In Preferences->General, do you have "Allow contacting web server for updates" checked?
Deadpool uses a newer version of BD+ protection, and the SVQ file for it was posted last week. If you have updates enabled AND your firewall allows them, you should be able to decode the movie. Debug logging will show that a different SVQ file was loaded for the disk.
andi219
Post by andi219 »
Hello Woodstock,
do you know if I can download the SVQ files manually?Automatic download doesn´t work for me.Ive switched of the firewall and I also allow makemkv to uptate.So I don´t know what to do.Or could it be that makemkv does not download the SVQ files because I ripped an older disc with BD+ 2010.9 and it is not necessary to download the new SVQ files?But MakeMkv tells me that the automatic download of SVQ files is deactivatet or failed.
Many greetings
I cannot answer that question... I only know that they're stored on makemkv.com somewhere, and how the system determines which one is the right one to download isn't in my memory bank. :)
andi219
Post by andi219 »
:) Thanks.
thattechwizard
Redid the movie to the SSD, that cured the issue.
thattechwizard
Woodstock wrote:In Preferences->General, do you have "Allow contacting web server for updates" checked?
I'll be sure to leave that ticked.
andi219
Post by andi219 »
I found the manually download of all SVQ files here:
/svq/dsall.svq
