Failed to Open Disk
Zaralyth
Failed to Open Disk
Post by Zaralyth »
Disk is not recent by any means.
Debug log started at Sat May 28 08:31:38 2016 , written by MakeMKV v1.9.7 win(x64-release)
Using 1048320KB for read cache.
001005:0000 MakeMKV v1.9.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Zaralyth/MakeMKV_log.txt
005075:0000 The new version 1.9.10 is available for download at /download/
003002:0000 Calculated BUP offset for VTS #0 does not match one in IFO header.
003002:0000 Calculated BUP offset for VTS #1 does not match one in IFO header.
003008:0000 Titleset start sector mismatch for titleset 1 : 87 != 73
003002:0000 Calculated BUP offset for VTS #2 does not match one in IFO header.
003008:0000 Titleset start sector mismatch for titleset 2 : 153 != 936554
003002:0000 Calculated BUP offset for VTS #3 does not match one in IFO header.
003008:0000 Titleset start sector mismatch for titleset 3 : 238 != 1587529
Title skip vts=1 pgcn=1 hash=743C45D921130D82
Title skip vts=2 pgcn=1 hash=4AD9E3455CCD90F8
vobs=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
001003:0020 DEBUG: Code 1849 at 9C3H$/%86~HdGI#j:121263383
001003:0020 DEBUG: Code 0 at ]o-?uYkGPg%n]o'=]}:29405292
001003:0020 DEBUG: Code 0 at ]o-?uYkGPg%n]o'=]}:29406833
003015:0000 Title #3 (0:00:06) was skipped due to navigation error
Title skip vts=3 pgcn=1 hash=82A4DD215EB92F69
Application exited at Sat May 28 08:31:51 2016
Re: Failed to Open Disk
I would recommend sending the files listed in the FAQ in my signature to support@makemkv.com so that Mike can have a look at them.
andi219
Post by andi219 »
You can also try to use the newest version of makemkv.Its 1.9.10.Ive seen that you use 1.9.7-it could be that its to old to rip newer discs.
Rusty
Post by Rusty »
I had this same problem and it turned out it was the DVD drive.. In my case, an off brand drive worked fine when a samsung would not.
