Hello.......
I have paid for MakeMKV in the past. I rebuilt my computer and some time later reinstalled MakeMKV to my computer. Do I have to buy it again or is there a way to retrieve my serial through you guys to activate the program past the 30 day trial...........
Buying MakeMKV
Re: Buying MakeMKV
If you no longer have the email from avangate.com that had the registration code in it, send your information to support@makemkv.com so that Mike can look it up and send your code to you.
cipher8
Re: Buying MakeMKV
Thank you for that. I just emailed and hopefully I am able to recover my code.
