im getting this error for a few days. Im on Debian Stretch with the latest makemkv.
When i try to run makemkvcon i get:
$makemkvcon
$makemkvcon: error while loading shared libraries: libavcodec-ffmpeg.so.56: cannot open shared object file: No such file or directory
So this can be true because i have installed (probably upgraded) to libavcodec57.
What should i do?
Errormessage: Application failed to initialize on Linux
Re: Errormessage: Application failed to initialize on Linux
Got it, i had to recompile it. It´s working now.
Tried upgrading 1.9.7 to 1.9.10 (compiled with ffmpeg 3.0.2). Getting this message when starting the gui. I don't use the console so I can only say that the usage message displays without error.
I just rebuilt, this time using ffmpeg 2.7.3. Still getting "Application failed to initialize" error.sblack55 wrote:Tried upgrading 1.9.7 to 1.9.10 (compiled with ffmpeg 3.0.2). Getting this message when starting the gui. I don't use the console so I can only say that the usage message displays without error.
zeroeffect96
I am running into the same issue when upgrading from version 1.9.9 to 1.9.10. I have tried suggestions in this forum and on other site but I still have to revert back to version 1.9.9 to get the application to work. I have all ready purchased a key so that shouldn't be the issue. I have updated all dependencies too. What else should I be looking for?
Thank you for your time.
Did you just reuse the already unpacked folder "makemkv-oss-1.9.9"? If so, delete it and unpack again, then rebuilt and install as usual. I just stumbled on this myself.sblack55 wrote:I just rebuilt, this time using ffmpeg 2.7.3. Still getting "Application failed to initialize" error.sblack55 wrote:Tried upgrading 1.9.7 to 1.9.10 (compiled with ffmpeg 3.0.2). Getting this message when starting the gui. I don't use the console so I can only say that the usage message displays without error.
(I haven't tried the newest MakeMKV version myself yet.)
