The Witch 2015 - Bluray Not sure which track to pick.
There are a couple hundred tracks or whatever the correct term is all about 16 chapters 25.9GB. Does anyone know which is the right one? Strangely enough I had this same issue with the Last Witch Hunter.
This is an example of what I'm talking about if it helps
Title information
Name: The Witch (English)
Source file name: 00701.mpls
Duration: 1:32:26
Chapters count: 16
Segment count: 15
Segment map: 510,509,501,512,506,508,505,502,515,511,507,513,514,504,503
File name: The_Witch_t171.mkv
Title information
Duration: 1:32:26
Chapters count: 16
Segment count: 15
Re: The Witch 2015 - Bluray Not sure which track to pick.
I have a problem with this movie....boe_d wrote:Hello,
Title information
Duration: 1:32:26
Chapters count: 16
Segment count: 15
dear customer the disc you inserted cannot be displayed due to copyright restrictions.
please visit ( liongate website address ) or online store to purchase a genuine copy.
if you try to play back an original disc on your computer & experience a copy detected message please ensure that no copying or ripping tool is running while performing playback
I try RedFox AnyDVD HD 7.6.9.5 and DVDFab 9.2.3.9 and try play in Media Player Classic (for test pro protected) and this same.
Movie iso playable only in ArcSoft 5 ok and correct with AnyDVD. But problem is correct chapters with edited BD. I would like add subtitle with tsMuxer but tsMuxer keep this protection.
File 00701 not good. Correct is 00499 show it BDinfo first and you can see this in play with Media Classic... "copyright restrictions".
How see... play and get play time on 6minute with baby.
I've been told it is 680.
I do not know how to find it but today I got the message...than 00680 sorry.boe_d wrote:I've been told it is 680.
If it's the same version as the one I bought yesterday it's a 4 chapter 00499.mpls with duration 1:33:26 I believe.... YMMV Tho most of the titles show the same size, this is the only one with that duration and 4 chapters listed.
yes but add include warning info... 00680 correct, tested and play full.bikesquid wrote:If it's the same version as the one I bought yesterday it's a 4 chapter 00499.mpls with duration 1:33:26 I believe.... YMMV Tho most of the titles show the same size, this is the only one with that duration and 4 chapters listed.
Any chance you can provide correct segment map?bikesquid wrote:If it's the same version as the one I bought yesterday it's a 4 chapter 00499.mpls with duration 1:33:26 I believe.... YMMV Tho most of the titles show the same size, this is the only one with that duration and 4 chapters listed.
This might be right, might not as I haven't watched the mkv yet.dashocker wrote:Any chance you can provide correct segment map?bikesquid wrote:If it's the same version as the one I bought yesterday it's a 4 chapter 00499.mpls with duration 1:33:26 I believe.... YMMV Tho most of the titles show the same size, this is the only one with that duration and 4 chapters listed.
Segment map: 510,2023,501,512,508,509,503,502,511,506,513,505,514,515,507,504
File name: The_Witch_t130.mkv
Can anyone confirm the right mpls or segment map? I see two conflicting ones in this thread and dont know if they pertain to my specific red version
Just tried both of the files mentioned here....00499.mpls and 00680.mpls. Both successfully processed.....however, 00499 had the end credits in the middle of the mkv file. 00680 worked perfectly and is in the proper sequence. The segment map is Segment map: 510,509,512,501,506,508,502,505,515,514,513,511,507,504,503.
biggleboi79
Thanks THenryJr! It worked perfectly.
Thank you!THenryJr wrote:Just tried both of the files mentioned here....00499.mpls and 00680.mpls. Both successfully processed.....however, 00499 had the end credits in the middle of the mkv file. 00680 worked perfectly and is in the proper sequence. The segment map is Segment map: 510,509,512,501,506,508,502,505,515,514,513,511,507,504,503.
FYI, for UPN 31398227861 the above map is actually on 680.mpls if anyone has that version.
ThirdDraft
File 00499 seems to be the working title for this in my experience. I tried 00680 and noticed a message at about 6:30 minutes (after the girl scares the infant) into the film a silent, black screen with a message asserting the movie could not be copied due to copyright something or other. Anyone else get the same message in that or any other title? In title 00499 the segment sequence looks like the copied info below- I couldn't find any other file with the same segment sequence to compare. Also, I notice in other titles I tested that in chapter 7 a scene where the boy is going into the woods gets cut abruptly by another scene where the dad and girl are in then comes right back to the boy in the woods, whereas when I watch it directly from the disc on the set top player it doesn't separate the two scenes like that. Somebody above also mentioned the in title 00499 the end credits are placed in the middle of the film somewhere, but I didn't get that, in my rip the end credits are at the end where they should be. I vouch for file 00499 as the proper working file, but I wonder if the inconsistency of errors mentioned here have anything to do with whatever hardware we are using to make the rip...???
Title information
Source file name: 00499.mpls
Duration: 1:33:26
Chapters count: 4
Segment count: 16
Title information
Duration: 1:33:26
Chapters count: 4
Segment count: 16
Just throwing in that
Title information
Source file name: 00680.mpls
Duration: 1:32:26
Chapters count: 16
Segment count: 15
File name: The_Witch_t166.mkv
Works for me.
Thumbnails from MPC:HC of 680 (t166) and 499 (t130)
Title information
Duration: 1:32:26
Chapters count: 16
Segment count: 15
Works for me.
