Now, I'm using PLEX...and need to convert some .ISOs.
I converted one, and was left with 9 .mkv "titles". I tried putting them in a folder, and having PLEX read that; but I get a playback error...so I assume I'm doing something wrong.
Thanks,
Well I guess my MKV question was this: why would one movie...be broken into 9 files?Woodstock wrote:Plex errors would have to be handled by the Plex people - "an error" could be anything.
Plex, in general, can handle MKV files just fine, but only they can tell you what your error means.
In this case...I have no doubt you're right. So...is that a "limitation" of MakeMKV; if you have a title, where you want to capture "extras"...there's no way, to "mux" them into one playable file?Woodstock wrote:"One movie" may have multiple files - MakeMKV probably extracted all the extras, too.
I would suggest you try playing the files with a program on your computer, such as VLC (from videolan.org), to see what is IN the files.
Everything above is a guess; with no information to work from, there isn't a lot anyone can say.
