Daddys Home error
aussie_0112
Daddys Home error
Post by aussie_0112 »
Debug log started at Sat May 21 17:00:12 2016 , written by MakeMKV v1.9.10 win(x64-release)
001005:0000 MakeMKV v1.9.10 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Kevin/MakeMKV_log.txt
DEBUG: Code 2147483648 at sOvXbpqt9^7}HS}M:121265315
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=J3CG+AezVisboFrmsb1dZISixLIeZBMdHVhtv4rbuzp3din84ysCbvnhvlJ7OMQDxS+HptgCmjBzgFa/Vcq2XANfrJbYHOGbHxKzfg18aMWmJazILihFqufAPeTw/OUaiCTIuDEBGtYyGhdDhWw1+r1PnBisvn7wnQ==
DCE=eK73Fs7/oulQksBl5xOeT2aZZpne+IZU+BRp/2GTAXb12VV3vX9fGYacfYk2zBtYV6oGTczZfmmpW9Ph1DPtMrLTMbCE4YngkMpj0pZsRTlMxnRs8UNxV6hfcKdh70R2YCEFkc+tJTJC6zVWHfZZKF4DmHyxr/Qj3Q==
DISCID=1AE8C155DD1C9461402322D577AE4523C87343F9
003307:0000 File 00800.mpls was added as title #0
003025:0000 Title #00020.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00250.m2ts was added as title #1
003025:0000 Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01007.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01008.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01009.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01010.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01011.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00053.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 01068.m2ts was added as title #2
003307:0000 File 01069.m2ts was added as title #3
003307:0000 File 01070.m2ts was added as title #4
003307:0000 File 01071.m2ts was added as title #5
003307:0000 File 01072.m2ts was added as title #6
003307:0000 File 01073.m2ts was added as title #7
003307:0000 File 01074.m2ts was added as title #8
003307:0000 File 01075.m2ts was added as title #9
003025:0000 Title #01076.m2ts has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01077.m2ts has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01078.m2ts has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01079.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory F:/Video/Daddy's_Home
001003:0020 DEBUG: Code 3221225628 at B!(/bh!*h=e\" *Nf4\%nlbY.:213131732
001003:0020 DEBUG: Code 3221225628 at k%fCkA+t|-[9U$=~:29393953
001003:0020 DEBUG: Code 100864261 at 9i#_2h?[1{cOG;n^:121269731
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4837343232'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '4837343232'
DEBUG: Code 3221225628 at 2MVwp'6i?!q.f(gN{R:213130904
001003:0020 DEBUG: Code 3221225628 at 2MVwp'6i?!q.f(gN{R:121262969
DEBUG: Code 100864261 at 2MVwp'6i?!q.f(gN{R:213130904
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4840488960'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '4840488960'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '4840495104'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4840495104'
001003:0020 DEBUG: Code 100864261 at 2MVwp'6i?!q.f(gN{R:121262969
001003:0020 DEBUG: Code 0 at Q<#K&"i/;&wS;HZ9xtZK:121263291
001003:0020 DEBUG: Code 0 at L3)hgM(<In66W4UjI/er:121262302
001003:0020 DEBUG: Code 0 at Q<#K&"i/;&wS;HZ9xtZK:213130812
001003:0020 DEBUG: Code 2363523 at Q<#K&"i/;&wS;HZ9xtZK:29393286
001003:0020 DEBUG: Code 0 at .w=8R]__M]/VQ02hySCwU:29398967
005003:0000 Failed to save title 0 to file F:/Video/Daddy's_Home/Daddy's_Home_t00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sat May 21 17:18:17 2016
Im also getting error msg with ive tried cleaning the disk multiple time and the BDR drive is brand new ive sent the dump file to svq@makemkv.com
The Martian
Sister
Re: Daddys Home error
Is the drive an internal SATA drive, external USB-powered drive, removable laptop drive, or ???
Some of the error messages are consistent with the drive going off-line during the read, which should not happen with internal SATA drives, but CAN happen with removable and USB-powered drives.
aussie_0112
Its Internal LG BH16NS40 Blu-Ray Writer - SATA
I downloaded an older version of MakeMKV and got The Martian to work ill try Daddys home now
I have no problems with older BluRays the errors started appearing for me around the time Mad Max Fury Road came out so i stopped ripping my collection hoping an update would fix it but im still getting errors Ive replace my Blu-Ray Write i clean the disk i try multiple time and still get errors
aussie_0112
Daddys home is still coming up with an error with the older version of MakeMKV
Title #01000.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01001.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4837011456'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '4840685568'
DEBUG: Code 0 at Y|IF&],tF&yI9BW_ayAs:121263038
DEBUG: Code 0 at R}R^X=e:}TnPR/)k|fqy:121262302
DEBUG: Code 0 at Y|IF&],tF&yI9BW_ayAs:213130559
DEBUG: Code 2363616 at Y|IF&],tF&yI9BW_ayAs:29393286
DEBUG: Code 0 at dTY}Ut\3Z+1[99lR]yBK&:29398967
DEBUG: Code 0 at LgX)E}ige$8C!sK:5!|:29396414
DEBUG: Code 0 at b@+}(*}QxCKQ#8<e*:213131893
DEBUG: Code 0 at b@+}(*}QxCKQ#8<e*:121263406
DEBUG: Code 0 at b@+}(*}QxCKQ#8<e*:29393907
The uncorrectable medium errors are being reported by the operating system; if the drive can't read parts of the disk, there isn't much MakeMKV can do. And isolated unreadable areas are often because of fingerprints or other "stuff" on the surface.
