The Judge Blu ray
Free_soul
The Judge Blu ray
Post by Free_soul »
Hello.
I can't copy the movie the judge because this problem at the beginning:
http://i.imgur.com/U4MA398.png
and later there are a lot of error messages "the file xxx.m2ts is damaged in the xxxx position..."
Thanks in advance.
Re: The Judge Blu ray
The drive is saying it has trouble reading the disk. The errors in the picture say that the directory portion of the disk isn't readable, at least not reliably.
Have you cleaned the disk, and made sure there are no cracks in the hub area?
Free_soul
Post by Free_soul »
Many thanks for the quick response Woodstock.
The surface is clean and there aren't any sign of "damage" on it.
This is the third copy of this movie I get and the problem is the same, and I had to ask just in case it's a known issue.
Thanks again.
P.S.: one more time forced to sail the ... waters of piracy :P (where the hell is the buccaneer smiley...?)
MrVideo
Post by MrVideo »
Free_soul wrote:The surface is clean and there aren't any sign of "damage" on it.
Try making an ISO backup of the disc with ImgBurn. If you get a disc protected message from ImgBurn, ignore it.
Free_soul
Post by Free_soul »
Thanks MrVideo.
Created the iso image successfully but with errors:
http://i.imgur.com/0Xge0bo.jpg
But makemkv continues the same (file is damaged... trying to fix):
http://i.imgur.com/5fD3mhK.png
Sadly, not too much hope here :x
Thanks anyway.
MrVideo
Post by MrVideo »
Free_soul wrote:Thanks MrVideo.
Intersting. ImgBurn usually shows which sector of the disc it is trying to read. At least it does for me. From what I could see, it was able to get through the read issues. You need to use the file that ImgBurn created.
Free_soul
Post by Free_soul »
Another unsuccessful ending.
I will try with another copy (libraries in barcelona) and if another "not happy ending" I'll turn to the dark side :mrgreen:
Many thanks to everybody.
