Rips have no audio
mlefoo
Rips have no audio
Post by mlefoo »
Hello, I have tried ripping two movies now and they both have not had any audio. I did a previous rip and the audio track was present but that was back in the middle of winter. The audio boxes are checked when i go to begin the rip. Any idea why I am not getting audio?
Re: Rips have no audio
How do you know you're not getting audio?
Check your playback software - you may have disks that have audio not supported by the player. Try playing them in VLC (from videolan.org), and check the Audio menu to see what is available.
mlefoo
Post by mlefoo »
Woodstock wrote:How do you know you're not getting audio?
I tried the movies that werent giving me audio in VLC and they would not play at all. I tried the movie that I had already ripped and it played in VLC. does this mean the two movies i was trying to rip have yet to be supported/unlocked by VLC or MakeMKV, or could this be something else?
It could be something else - do you have debug logging turned on, and can you post the log from the rip? (FAQ in signature tells you how to do that)
