Amer 2009
tomcat3281
Amer 2009
#1 Post by tomcat3281 » Wed May 18, 2016 11:21 pm
Amer 2009
http://www.imdb.com/title/tt1426352/
Olive Films
using Samsung Portable BD Writer Model SE-506
Failed to save title 0 to file C:/Users/NAME/Desktop/~movies/OUT/Amer_t00.mkv
0 titles saved, 1 failed
MakeMKV v1.9.10 win(x64-release) started
Title #00008.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00006.mpls was added as title #0
File 00014.mpls was added as title #1
File 00014.m2ts was added as title #2
File 00013.m2ts was added as title #3
File 00012.m2ts was added as title #4
Title #00011.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00015.m2ts was added as title #5
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Users/NAME/Desktop/~movies/OUT
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00007.m2ts' at offset '17293639680'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '17293639680'
Re: Amer 2009
#2 Post by Woodstock » Wed May 18, 2016 11:55 pm
The drive is having issues reading the disk. However, it may be because of power issues - the fact that the drive was inaccessible for a short time after the first error often means the drive was resetting.
Two ways to approach this - first is to make sure the disk is clean.
The second is to make sure the drive has full power available to it. If you are NOT plugging it into the computer directly, make sure the hub you plug it into has its own power. If it is plugged into a laptop, make sure the laptop is plugged in and charging.
Mike has mentioned someday adding a "speed limiter" to work around this issue, but he hasn't said anything recently about adding that feature...
