Hi this is the info
MakeMKV v1.5.4 beta win(x64-release) started
Calculated BUP offset does not match one in IFO header.
Cell 1 was discarded (structure protection?)
Cells 2-9 were skipped due to cell commands (structure protection?)
Title #0 was added (29 cell(s), 1:29:44)
Title #1 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 was added (8 cell(s), 0:49:39)
Title #6 was added (3 cell(s), 0:12:27)
Title #7 was added (3 cell(s), 0:10:16)
Title #8 was added (3 cell(s), 0:08:50)
Title #9 was added (3 cell(s), 0:07:49)
Title #10 was added (3 cell(s), 0:05:26)
Title #11 was added (3 cell(s), 0:10:46)
Title #12 has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 was added (2 cell(s), 0:11:05)
Title #14 was added (2 cell(s), 0:07:42)
Title #15 was added (2 cell(s), 0:02:53)
Title #16 was added (22 cell(s), 0:11:47)
Title #17 has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #21 has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24 has length of 51 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25 has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #26 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #27 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #28 has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #30 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #31 has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #32 has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #34 has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #35 has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #36 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #38 was added (2 cell(s), 0:02:53)
Title #39 has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #40 has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory C:/Users/Michael/Videos
Failed to save title 0 to file C:/Users/Michael/Videos/t00_Resident_Evil_Apocalypse.mkv
0 titles saved, 1 failed
avq files download. how?
Krobar
Re: avq files download. how?
Does it error at the beginning of ripping or right at then end? Are they all UK DVDs?
mikeinessex
it happens right at the end. you see at the bottom of the info says o titles saved. and yep all uk
mikeinessex
i think its the decrypter cause it works on other dvds just seems like the newer ones then other dont work. im going to try dvd43 and see if that sorts the decrpting out
mikeinessex
have u had this problem before krober
Krobar
Hmm, I only have an R1 copy of Apocalypse. What are the other DVDs you are having problems with?
Krobar
With only 3 or 4 discs out of the 120 I have tried, usually rare titles. I have lots of R2 DVD so if you can let me know of any others that do this I can maybe try them myself.mikeinessex wrote:have u had this problem before krober
mikeinessex
spiderman 3, die hard 4.0. i havent tried any more of that age or newer yet
mikeinessex
is there other software or updates your pc should have what may effect it? sounds like silly question but im desperate to find a answer cause part from not being able to do every dvd i try i think its the best software i have used for quality
Krobar
I'm Blu for those. Its not new titles in particular though, Men Who Stare At Goats and GI Joe copied OK for me. See if you can find any others, also please enable debugging in preferences and post the TXT file here, it should give more info.mikeinessex wrote:spiderman 3, die hard 4.0. i havent tried any more of that age or newer yet
mikeinessex
here is the log for spiderman 3
mikeinessex
fatal error accured application will now close it says thats while i was openin the disk so i didnt even get to the titles and ripping with that one
Krobar
Maybe try forcing CellTrim in preferences. If that fails follow the instructions here to report this type of bug:mikeinessex wrote:here is the log for spiderman 3
http://www.makemkv.com/faq/item/8/catid/6
mikeinessex
ok ill try c if it works. in middle of rippin aliens 3 so do it after that. someone else ealier on this thread said all the ones i stated have been ripped an work. well if so y not for me lol
mikeinessex
btw thanks for helping. its nice someone takes time to help out rather then leave people to struggle
