newby how do i run the file
bigdickau
Post by bigdickau »
Hi to all
i am new to this program and have just backed up my first file but cannot run it.
most likely a easy answer
many thanks
Richard
Re: newby how do i run the file
What do you mean, "run the file"? Are you referring to playing an MKV file, or starting MakeMKV?
bigdickau
Post by bigdickau »
Yes i meant play a bluray file
The fact that you said "backup" means you probably used the "backup" function, which creates an image (optionally decrypted) of the Bluray data on the disk.
The next question is, what operating system, and what software do you have installed?
Windows prior to 10 has no support built in for playing BD files. Programs like VLC from Videolan.org do recognize unencrypted Bluray folders. Some media players can handle BD folders, as well. Smart TVs.... BD-aware ones might exist, but I have not seen one myself.
