Independence Day 20th Anniversary Edition
zombiehorde
Upon opening BD+ code processed but no FUTs were obtained, errors may follow. If I continue and select the track for extraction, it pulls approximately 6gb and then stalls forever. What do the developers need to debug the copy protection?
Re: Independence Day 20th Anniversary Edition
/svq/ explains the process.
dvdlovr24
I sent my dump file earlier. Hopefully it won't be too long before MakeMKV can rip it.
zombiehorde
Thanks guys. I will utilize the SVQ link next time since dvdlovr24 already sent his dump file. Thanks, for that, by the way.
ZMan2k2
I don't know if you got around to this one yet, or if the Canadian version is different. But it still won't copy, says no FUT's were found. I'll try and figure out how to send the svq out.
Got it figured out. Here's the dump for the Canadian version.
https://drive.google.com/open?id=0B1zjm ... jdKd0lMV2s
Please send the link to svq@makemkv.com so that Mike sees it sooner. He checks mail more often than the board.
ZMan2k2
Sorry. Done. Thanks.Woodstock wrote:Please send the link to svq@makemkv.com so that Mike sees it sooner. He checks mail more often than the board.
whoretoilet
sketchball
I'll go ahead and pile on and say I've sent my dump as well. Same as whoretoilet, was able to rip after getting the FUT error msg, but lots of video distortion.
AndyMac
Is there someway to know when I can try ripping this disc again or do I just try it every few days? I'm still seeing the error as of 8:23am May 13th.
dvdlovr24
None that I know of. I just a couple of times a day and still no luck so far.AndyMac wrote:Is there someway to know when I can try ripping this disc again or do I just try it every few days? I'm still seeing the error as of 8:23am May 13th.
AndyMac
Thanks. I'll just keep checking here or try ripping it every few days. No big hurry.
MakOwner
No fix for this yet?
I'm using 1.99 and 1.910 on linux (licensed) and I get the no FUTs found -- it rips, but the output is corrupted.
AndyMac
I was able to rip this disc successfully this morning, May 17th.
whoretoilet
I was able to rip a copy as well tonight. I still got a bunch of A/V sync and frame drop errors but, the final file looks and sounds fantastic.
Thank you so much for such a quick turnaround!
