Disc Titel as filename
Christian72D
Post by Christian72D » Sun May 08, 2016 3:48 am
Most times i only want to rip the main titel from a DVD.
Wouldn´t it be more easy and fun if i could auto-set the titel of the disk as the file name of my ripped file?
Re: Disc Titel as filename
Post by Woodstock » Sun May 08, 2016 11:42 am
If you use the "Semi-auto" file naming setting, MakeMKV will attempt to set the file names to the disk title, but it is not an exact science (meaning it doesn't always work), and MakeMKV replaces spaces with "_" (which irritates a lot of us), and it wants to put a title number at the end (necessary for when there are more than one file to extract).
If you enable Expert Mode (Preferences->General), you can pre-name the file before you rip the disk.
