The Hunger Games Mockingjay Part 2 2015 US Release Blu-ray
Batiatus
Re: The Hunger Games Mockingjay Part 2 2015 US Release Blu-r
#61 Post by Batiatus » Sat May 07, 2016 7:26 pm
I hve a 3D disc and every single segment map starts with 614/603. Haven't seen anyone post their findings for this yet.
Man Lionsgate must waste so much time and money doing this just to try and frustrate people who still figure it out anyways. Such a waste.
andi219
#62 Post by andi219 » Sat May 07, 2016 8:20 pm
So it doesn´t wonder that we have to get a new Blueray-Player every year because the old one doesn´t work with the newest Blueray protections.Copying our bluerays with a program like makemkv is the only way to watch this protectet movies.
I copied Mockingjay 2 successful by clicking on the drive symbol after starting makemkv and choose title one.I dont know which is the right playlist when you make a full disc backup.
shamanjoe
#63 Post by shamanjoe » Thu May 19, 2016 11:46 pm
I just wanted to add a quick thanks. I had a hell of a time ripping the Mockingjay Part 2 REDBOX blu-ray, and after testing a couple of suggestions here, it seems like 134.mpls was the winner for that version. Thanks!
MrVideo
#64 Post by MrVideo » Sun May 22, 2016 6:41 am
andi219 wrote:So it doesn´t wonder that we have to get a new Blueray-Player every year because the old one doesn´t work with the newest Blueray protections.
You can't be serious. I've not run into that issue.
divine01
#65 Post by divine01 » Wed Dec 07, 2016 2:36 am
Ok, In case no one else came across this...This will definitely come in handy for cases where Procmon does not give you what you need. (as in the case with this release)
https://www.makemkv.com/forum2/viewtopic.php?f=1&t=7680
The basic gist is,
1. Determine the run time for your blu Ray.
2. Eliminate any .mpls that don't have that run-time.
3. Use MakeMKV to "Backup" the bluray. Choose the decrypt video option.
4. Move all the files that appear in every segment map to a separate folder (I copied the mpls numbers to excel to make sure I didn't miss any)
5. Typically, the start point will be the same segment number across all the mpls files. Find the next one by playing the end of the current one, and then the beginning of the next file until you find the right sequence. (go through all of them if you cannot easily find the next scene)
6. Now you should have 2 correct segments...Eliminate all the mpls files that do not have these first 2. Then find you next video, eliminate and so on.
The entire process (outside of the initial backup of the video files) took me maybe 15 minutes. So for cases where there are hundreds of potential mpls files, and procmon doesn't narrow it down to the correct one, this is an alternative way to get it done.
Hope this helps.
BTW-My MPLS file was 00428 in case anybody was curious.
BrennerM
#66 Post by BrennerM » Sat Jan 14, 2017 4:25 am
I have the Canadian version and did the legwork (backup, then look through the individual M2TS files) to find that 00706.mpls seems to be the correct playlist to use.
Title information
Name: Hunger Games: Mockingjay Part 2
Source file name: 00706.mpls
Duration: 2:16:57
Chapters count: 16
Segment count: 18
Segment map: 510,503,517,513,520,501,519,505,504,508,506,512,509,507,514,515,516,518
tomg66
#67 Post by tomg66 » Tue Apr 25, 2017 2:42 am
I have the retail blu-ray (+ digital HD) there is no UPC on the package that I can see. I assume it's the US release because I bought it at BestBuy in Utah. I've tried the different MPLS files described here (00706, 00600), and I've not found one that works, so I wrote a little bash script to search the MPLS files for the segment maps described in this thread, and I found that none of the files had a matching segment map. So..... as far as I can tell, there is still no way to know what the correct MPLS file is. But somewhere on the disk there has to be something that can programatically determine the correct MPLS to play. Any hints what this might be? i'm guessing it has to be something java related, because there is so much of that contained on the disk. Any ideas what it might be? Perhaps I could write something to do this automatically so there is no guesswork for any of the versions of the Lions Gate disks in the future.
Tom
E2theC
#68 Post by E2theC » Fri Mar 30, 2018 3:31 am
I know I am several years late getting to this, but I wanted to let you know that I believe MPLS 628 is correct for an unknown store-bought BD:
Summary for drive F: (AnyDVD HD 8.2.2.0, BDPHash.bin 18-01-30)
ELBY CLONEDRIVE 1.4
Drive (Hardware) Region: 1
Current profile: BD-R
Media is a Blu-ray disc.
Total size: 24407136 sectors (47670 MBytes)
Video Blu-ray label: MOCKINGJAY_2
Media is not AACS protected.
Java BD protection good playlists: 628
Bad sector protection not found.
coolaj86
Re: The Hunger Games Mockingjay Part 2 2015 US Release Blu-ray
#69 Post by coolaj86 » Mon Jun 08, 2026 5:15 pm
Update: It's 00428.mpls
Red insert w/ Katniss aiming arrow "Promo"
Sticker UPC: 0 31398 25641 0 (Promo, unlisted)
031398256410
Insert UPC: 0 31398 23989 5 (Walmart)
031398239895
Segments:
515 all logos to poisoned peeta
511 2nd peeta - she's a mutt too to walk out
506 snow has to pay
519 snow pays 2 to bad kiss
513 bad kiss part 2
516 bad kiss part 3 to in-plane plan
517 in-plane 2 to capital drop plan
503 plan in 13, propo, jonna, recovering peeta 0
518 recovering peeta 1
520 recovering peeta 2
505 recovering peeta 3
509 recovering peeta 4 to enter courtyard with reader
510 enter courtyard 2
514 enter courtyard 3 to pod
508 pod begins in courtyard w/ peeta transfer clearance
501 guy dies, capital fight begins to auto-destruct parking lot
502 tigress
504 tigress underground to crying avox
507 broke avox
512 "I'm so sorry" names of people dying through credits
Because I wanted the set to match with all red Katniss jewel inserts (rather than the typical white chair insert for part 2), I bought a "Promo" edition on ebay with the following details:
It has two different UPCs - the outer / top UPC is on a sticker. Using a flashlight to shine through the label on the back I was able to read the UPC underneath and used a UPC lookup site to determine that it's correct and listed for sale at Walmart.
Disc Name: MOCKINGJAY_2
I wasn't sure how to go about getting JRE set up to work with the MakeMKV snap on my Linux VM, so I booted up a Windows 10 VM and installed JRE + MakeMKV via the .exe installers and opened index.bdmv there to see what it suggests and got this:
Source information
Type: Blu-ray disc
Comment: Mockingjay Pt 2 Rental
INCORRECT
Title information
Comment: FPL_MainFeature
Source file name: 00821.mpls
Duration: 2:16:57
Chapters count: 16
Segment count: 20
Segment map: 515,506,516,513,517,511,519,503,505,520,518,509,514,510,508,501,502,504,507,512
File name: Hunger Games- Mockingjay Part 2-FPL_MainFeature_t03.mkv
INCORRECT
To figure out what it was I found the BDMV folder with the STREAM folder, dragged the .m2ts files into VLC. The longest two were the beginning and end. Then I went through and made notes of the beginning and end of each, then lined them up, then played beginnings and ends and cleaned them up.
