Dirty Grandpa - Which is the right mpls?
rose.athens
Post by rose.athens »
There are hundreds of mpls on this one. Do you have any idea which is the right one?
Meister_Proper
Re: Dirty Grandpa - Which is the right mpls?
Post by Meister_Proper »
Its supposedly 00573.MPLS
SampleMac
Post by SampleMac »
Anyone know the mpls for the US rental version -- there's no 573 on that one.
nick2421
Post by nick2421 »
coming up with 244.mpls via process monitor.
ripitagain
Post by ripitagain »
Redfox admin is reporting 244 mpls but it's not working for me and another member on that forum. Mpls 244 has video missing from when the lead actor is leaving the house to go to grandpa's house. He standing on the front lawn, then magically he's in grandpa's dinning room.
Also, my disk does not have mpls 573. I used the code *NOFILTER* to see if it was being skipped, which appears to not be the case.
I tired using Procmon with PowerDVD but it's not sticking with just one mpls like it usually does.
Thanks in advance,
edamollem
Post by edamollem »
Same here - I tried 244 however there are some sequences out of order.
Procmon throws a whole bunch of playlists when playback is initiated. 244 is just the last one - so who knows at this point......frustrating...
Axehandler
Post by Axehandler »
Title information
Source file name: 00410.mpls
Duration: 1:42:02
Chapters count: 16
Segment count: 20
Segment map: 507,502,508,515,514,510,520,505,518,517,504,511,513,519,512,501,503,516,509,506
File name: Dirty_Grandpa_t123.mkv
afletcher
Post by afletcher »
Axehandler wrote:Title information
Duration: 1:42:02
Chapters count: 16
Segment count: 20
410 worked for me.
I'm curious how you came to this conclusion. Process Monitor spit out about 20 .mpls's when I pushed play in PowerDVD 14. 410 was somewhere in the middle.
ripitagain
Axehandler - thanks for the mpls. I watched it at 2x speed with subtitles on, didn't see any issues.
I'm curious as well, as to how you locked in the correct mpls?
Axehandler
Manual labor....
Almost every one of them began with 507 and ended with 506. I just opened the the files to find that 502 then 508 and 515 were then next videos.
Didn't really need to search much more after that..... just find the one with 507,502,508,515.
I think I found 2 or 3. was a simple process of elimination from there.
Axe
gereral1
Post by gereral1 »
ripitagain wrote:Redfox admin is reporting 244 mpls but it's not working for me and another member on that forum. Mpls 244 has video missing from when the lead actor is leaving the house to go to grandpa's house. He standing on the front lawn, then magically he's in grandpa's dinning room.
Thanks in advance,
Try cashed protection video. Or alldup method to reveal.....
gereral1
Post by gereral1 »
Set .m2ts filter as you play at 16x WILL SHOW the segment map!
DJRumpy
Post by DJRumpy »
I don't have any of these. Target, UPN 31398244110
DJRumpy
Post by DJRumpy »
Mine is the unrated edition from Target (UPN in the post above). All of my maps start with 517.
Has anyone else gotten this version and figured out the proper title?
DJRumpy
Post by DJRumpy »
Confirmed for UPN 31398244110, MPLS 573 is the correct one.
