Dirty Grandpa - Which is the right mpls?
rose.athens
#1 Post by rose.athens » Fri May 06, 2016 9:39 am
There are hundreds of mpls on this one. Do you have any idea which is the right one?
Meister_Proper
Re: Dirty Grandpa - Which is the right mpls?
#2 Post by Meister_Proper » Fri May 06, 2016 1:31 pm
Its supposedly 00573.MPLS
SampleMac
#3 Post by SampleMac » Tue May 17, 2016 4:07 pm
Anyone know the mpls for the US rental version -- there's no 573 on that one.
nick2421
#4 Post by nick2421 » Tue May 17, 2016 7:22 pm
coming up with 244.mpls via process monitor.
ripitagain
#5 Post by ripitagain » Wed May 18, 2016 12:11 am
Redfox admin is reporting 244 mpls but it's not working for me and another member on that forum. Mpls 244 has video missing from when the lead actor is leaving the house to go to grandpa's house. He standing on the front lawn, then magically he's in grandpa's dinning room.
Also, my disk does not have mpls 573. I used the code *NOFILTER* to see if it was being skipped, which appears to not be the case.
I tired using Procmon with PowerDVD but it's not sticking with just one mpls like it usually does.
Thanks in advance,
edamollem
#6 Post by edamollem » Wed May 18, 2016 1:23 am
Same here - I tried 244 however there are some sequences out of order.
Procmon throws a whole bunch of playlists when playback is initiated. 244 is just the last one - so who knows at this point......frustrating...
Axehandler
#7 Post by Axehandler » Wed May 18, 2016 2:50 am
Title information
Source file name: 00410.mpls
Duration: 1:42:02
Chapters count: 16
Segment count: 20
Segment map: 507,502,508,515,514,510,520,505,518,517,504,511,513,519,512,501,503,516,509,506
File name: Dirty_Grandpa_t123.mkv
afletcher
#8 Post by afletcher » Wed May 18, 2016 4:13 am
Axehandler wrote:Title information
Duration: 1:42:02
Chapters count: 16
Segment count: 20
410 worked for me.
I'm curious how you came to this conclusion. Process Monitor spit out about 20 .mpls's when I pushed play in PowerDVD 14. 410 was somewhere in the middle.
ripitagain
#9 Post by ripitagain » Wed May 18, 2016 4:36 am
Axehandler - thanks for the mpls. I watched it at 2x speed with subtitles on, didn't see any issues.
I'm curious as well, as to how you locked in the correct mpls?
Axehandler
#10 Post by Axehandler » Wed May 18, 2016 3:44 pm
Manual labor....
Almost every one of them began with 507 and ended with 506. I just opened the the files to find that 502 then 508 and 515 were then next videos.
Didn't really need to search much more after that..... just find the one with 507,502,508,515.
I think I found 2 or 3. was a simple process of elimination from there.
Axe
gereral1
#11 Post by gereral1 » Wed May 18, 2016 4:20 pm
ripitagain wrote:Redfox admin is reporting 244 mpls but it's not working for me and another member on that forum. Mpls 244 has video missing from when the lead actor is leaving the house to go to grandpa's house. He standing on the front lawn, then magically he's in grandpa's dinning room.
Thanks in advance,
Try cashed protection video. Or alldup method to reveal.....
gereral1
#12 Post by gereral1 » Wed May 18, 2016 4:26 pm
Set .m2ts filter as you play at 16x WILL SHOW the segment map!
DJRumpy
#13 Post by DJRumpy » Wed May 18, 2016 8:04 pm
I don't have any of these. Target, UPN 31398244110
DJRumpy
#14 Post by DJRumpy » Thu May 19, 2016 12:49 am
Mine is the unrated edition from Target (UPN in the post above). All of my maps start with 517.
Has anyone else gotten this version and figured out the proper title?
DJRumpy
#15 Post by DJRumpy » Thu May 19, 2016 11:51 pm
Confirmed for UPN 31398244110, MPLS 573 is the correct one.
