The Dilemma Blu-Ray 2011
dmoor1
Post by dmoor1 » Thu May 05, 2016 12:09 pm
I tried to create a dump file but the dump hung when the main title was selected.
Here's what the log file shows:
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00010.m2ts' at offset '3395420160'
Error 'Posix error - Device not configured' occurred while reading '/dev/rdisk2' at offset '3395420160'
DEBUG: Code 1073741830 at N;87||f5zz=H&u>Wt_:121262969
DEBUG: Code 2281701379 at N;87||f5zz=H&u>Wt_:121262969
DEBUG: Code 0 at =^M4rI33W2cx/\Cfg0*W:121263291
DEBUG: Code 0 at :Etg}tshH7JYI{stw<}i:121262302
DEBUG: Code 0 at =^M4rI33W2cx/\Cfg0*W:213130812
DEBUG: Code 1657920 at =^M4rI33W2cx/\Cfg0*W:29393286
DEBUG: Code 0 at g/>>m:Vzl/$+*U=='upDy:29398967
DEBUG: Code 0 at 4J^(03;JK{JV]^A[f8w:213132767
DEBUG: Code 0 at 2Bwk\16/U&U(|x,c!:213131893
DEBUG: Code 0 at 2Bwk\16/U&U(|x,c!:121263406
DEBUG: Code 0 at 2Bwk\16/U&U(|x,c!:29393907
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 0 to file /Users/dmoor/Movies/The_Dilemma/The_Dilemma_t00.mkv
0 titles saved, 1 failed
DEBUG: Code 2281701379 at `-+6{6pNmTgC3Yr>:213134676
and this line repeats hundred of times ....
Re: The Dilemma Blu-Ray 2011
Post by Woodstock » Thu May 05, 2016 2:28 pm
Is this an external, USB powered drive? Maybe an internal drive on a laptop?
If so, make sure it is plugged into a port that has adequate power available. If it is plugged into a laptop, make sure the laptop is plugged into power. If it is plugged into a hub, make sure the hub has its own power supply.
USB powered drives are notorious for not getting sufficient power when they're running at full speed. MakeMKV runs drives at full speed. And the drive goes "off line" in the middle of ripping.
