Homeland Season 5 BD+ Code FUT may cause errors.
chicken007
Hi all, anyone else had a problem with Homeland Season 5, audio is fine but video is not clear?
Re: Homeland Season 5 BD+ Code FUT may cause errors.
When you ripped the disk, there should have been a TGZ file created, and a link to where it was saved in the log section of MakeMKV. You need to send that file to svq@makemkv.com so that it can be analyzed, and a fix implemented.
You can find more information at /svq/
chicken007
Fantastic, thank you so much for your help! Have just done this!
