select output resolution?
ryukenden
Post by ryukenden » Sat Apr 23, 2016 7:34 pm
I ripped a blu-ray movie but the output is like 12gb in 1080p. I want to make it 720p, is there a easy way instead of reconverting again with another program?
Lovely Rita
Re: select output resolution?
Post by Lovely Rita » Sat Apr 23, 2016 10:04 pm
Registered User :wink:
Buy MakeMKV
Post by Woodstock » Sat Apr 23, 2016 11:22 pm
As Rita points out, MakeMKV isn't going to do it - you MUST recode the video if you're changing its resolution, and a tool like handbrake is the way to go.
MilesAhead
Post by MilesAhead » Sat May 21, 2016 6:51 pm
ryukenden wrote:I ripped a blu-ray movie but the output is like 12gb in 1080p. I want to make it 720p, is there a easy way instead of reconverting again with another program?
An alternative to changing the resolution is to reduce the bit rate. I have used
BD Rebuilder to compress .m2ts files of that size to 5 GB and they still look good. btw I often used MakeMKV to get that .m2ts file.
