The Revenant
bernard
The Revenant
#1 Post by bernard » Tue Apr 19, 2016 10:42 pm
The Revenant was just released and I got the popup "BD+ code processed but no FUTs were obtained, errors may follow." I tried to attach the dump_The_Revenant_067155017E2B743F.tgz, but it was 4.6 MB, too large for the forum. The output mkv file is created, but when played it has lots of video defects. I tried attaching an image but "the board attachment quota has been reached." The log file is shown below. Please advise. Thanks.
MakeMKV v1.9.10 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Bernard/MakeMKV_log.txt
Loaded 306 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
DEBUG: Code 0 at }p*neP- w<%,+(r<:121263843
DEBUG: Code 0 at }p*neP- w<%,+(r<:29394275
DEBUG: Code 0 at }p*neP- w<%,+(r<:121272606
Saved BD+ dump file as C:\Users\Bernard/.MakeMKV/dump_The_Revenant_067155017E2B743F.tgz
Title #00191.mpls has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00170.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00171.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00172.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #0
File 00200.mpls was added as title #1
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title 00801.mpls is equal to title 00800.mpls and was skipped
Title 00851.mpls is equal to title 00800.mpls and was skipped
Title #00070.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00111.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00119.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00124.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00126.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00128.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00129.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00130.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00132.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00134.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00135.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00136.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00137.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00138.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00140.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00142.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00143.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00191.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00077.m2ts has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00170.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00171.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00149.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00172.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00089.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00192.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00399.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00173.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00174.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00175.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00398.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00397.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 2 titles into directory //FREENAS/data/Movies/The Revenant using profile 'FLAC' from file 'C:\Program Files (x86)\MakeMKV/flac.mmcp.xml'
Forced subtitles track #6 turned out to be empty and was removed from output file
Forced subtitles track #3 turned out to be empty and was removed from output file
Forced subtitles track #5 turned out to be empty and was removed from output file
Forced subtitles track #7 turned out to be empty and was removed from output file
Forced subtitles track #9 turned out to be empty and was removed from output file
2 titles saved
mightyquinn
Re: The Revenant
#2 Post by mightyquinn » Tue Apr 19, 2016 10:57 pm
I had the exact same problem.
Sloshy
Re: The Revenant
#3 Post by Sloshy » Wed Apr 20, 2016 12:36 am
Can confirm, audio seems to rip fine but the video is glitchy and only partially correct in any scene.
Re: The Revenant
#4 Post by Woodstock » Wed Apr 20, 2016 12:40 am
The BD+ dump file needs to be emailed to svq@makemkv.com of, if your email service won't let you email something that big, you will need to put it somewhere that Mike can download it from, and a link sent to the above email address.
gana2k1@gmail.com
Re: The Revenant
#5 Post by gana2k1@gmail.com » Wed Apr 20, 2016 12:57 am
I had exactly the same error. It is still ripping, but as requested, sent email with the bd+ dump file.
UncleRon
Re: The Revenant
#6 Post by UncleRon » Wed Apr 20, 2016 1:49 am
Don't want to just be duplicate, but I had exact same problem. In -years- using the great MakeMKV, this is a first.
bernard
Re: The Revenant
#7 Post by bernard » Wed Apr 20, 2016 1:56 am
I sent the dump file but I had to delete the .jar files in BDMV/JAR from the archive because my email server won't send files that look like executables.
trogdorsmith
Re: The Revenant
#8 Post by trogdorsmith » Wed Apr 20, 2016 2:14 am
I sent dump file as well. (if by dump file that is the TGZ file) I have means to get whatever is needed sent over, but is that all that is needed, or files from the disc itself?
Sorry for asking. I've done some searching, and find different things that need to be sent over for different situations, and I don't want to send a bunch of stuff that doesn't need to be sent.
gana2k1@gmail.com
Re: The Revenant
#9 Post by gana2k1@gmail.com » Wed Apr 20, 2016 2:55 am
I sent the tgz file. I had to rename it as .txt - otherwise gmail will bounce it back saying not allowed files to be sent.
UncleRon
Re: The Revenant
#10 Post by UncleRon » Wed Apr 20, 2016 11:41 am
This is the first time in -years- of using MakeMKV that I have ever had to be in this support forum. What is the usual outcome of a failure like this? I see that other titles in the past have had these symptoms. Does the cause usually get discovered and fixed? Is it a "batch" of manufacturing encoding that is not on all discs of this title? Is this a "new" thing that spells doom for us?
Re: The Revenant
#11 Post by Woodstock » Wed Apr 20, 2016 12:47 pm
Usual outcome is that Mike analyzes the samples, and generates an SVQ file that MakeMKV can use to interpret the BD+ data. That is then available for MakeMKV to download as needed, provided you have "Allow contacting web server for updates" turned on in Preferences->General.
Every few days, try the rip again - if Mike has finished, it will "suddenly" work. Getting the BD+ warning means he hasn't gotten to it yet.
UncleRon
Re: The Revenant
#12 Post by UncleRon » Wed Apr 20, 2016 1:23 pm
Woodstock, THANKS. I didn't know all this because I have -never- had a problem with MakeMKV. It falls into the rare category of TERRIFIC SW. Many thanks to Mike and all the "ninjas."
gana2k1@gmail.com
Re: The Revenant
#13 Post by gana2k1@gmail.com » Thu Apr 21, 2016 1:00 am
Thanks Woodstock - that's what I thought would happen :-)
Keeping my fingers crossed - restarted MakeMkv and just tried again - I see a difference now in that it is using a new disc specific svq - before debug message indicated it was using generic svq.
Processing BD+ code using disc-specific SVQ from C:\Users\myuser/.MakeMKV/00000197.svq.
Hopefully this will clear the video choppiness/defects as mentioned by OP.
gana2k1@gmail.com
Re: The Revenant
#14 Post by gana2k1@gmail.com » Thu Apr 21, 2016 1:37 am
Nice - I can confirm with the latest svq, no error and no video artifacts like before. Thanks Mike for the super quick response.
UncleRon
Re: The Revenant
#15 Post by UncleRon » Thu Apr 21, 2016 2:42 am
YES! Done and Done! Thanks Mike and to all the 'ninjas' for getting this fixed. Wonderful. Perfect.
