1.9.10 with OS 10.11.4: ripping doesn't work anymore
Kewler
Post by Kewler »
I tried to rip a BD and I got a error message. So, to test if everything was OK, I tried ripping another BD that I successfully ripped a few years ago with the same BD drive and even that one didn't work anymore...
OS X 10.11.4, MakeMKV 1.9.10
Error message for the BD that was ripped a few years ago:
MakeMKV v1.9.10 darwin(x86-release) started
Optical drive "BD-RE Optiarc BD RW BD-5750H 1.00" opened in DASPI v1.5 mode.
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/AACS/ContentHash000.tbl' at offset '0'
Failed to load content hash table, unable to verify integrity of M2TS files.
Failed to get BD disc information, reporting double-layer BD-ROM to BD+ code
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDSVM/00000.svm' at offset '0'
BD+ dump directory is not accessible, BD+ dump not saved
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
Kewler
Re: 1.9.10 with OS 10.11.4: ripping doesn't work anymore
Post by Kewler »
Seems to be an OS issue: I tried with another MacBook Pro with OS 10.9.5 and it works. Permissions maybe?
The operating system is not talking to the drive properly. Usually this means the drive is considered "off line". If it were Windows I'd suggest powering down and restarting. Might work for OS X as well.
Kewler
Post by Kewler »
Yes, I did try that, made no difference. Maybe then the DASPI driver is the problem? I'll try without it tomorrow.
Thanks for the hint.
Mike posted a message a year or so back that said that DASPI should ONLY be installed if MakeMKV asked for it... It was always needed in the past, but newer versions of OS X usually worked fine without it.
Kewler
Post by Kewler »
Woodstock wrote:Mike posted a message a year or so back that said that DASPI should ONLY be installed if MakeMKV asked for it.
Oh, you mean like this message http://www.makemkv.com/forum2/viewtopic ... 635#p28051 where Mike was telling that to... me?
In my defence, that was almost three years ago... :wink:
Thanks.
Kewler
Post by Kewler »
Ripped without a hitch with DASPI removed. Thanks!
