Windows 10 install - Insufficient system resources
kleinschmidt
Post by kleinschmidt » Sun Apr 17, 2016 9:28 pm
I am trying in run Setup_MakeMKV_v1.9.10.exe on a Windows 10 system.
There are 111 GB free on the C: drive and
task manager reports 2.2 GB out of 3.9 GB RAM in use.
Yet when I run the Setup, I get the message:
"Insufficient system resources exist to complete the requested service."
I rebooted and tried again. Same result.
Any clue what resource is insufficient? What else might be creating the problem?
Re: Windows 10 install - Insufficient system resources
Post by Woodstock » Sun Apr 17, 2016 11:32 pm
Have you checked the Windows Event Viewer to see if it has any information on the problem?
kleinschmidt
Post by kleinschmidt » Mon Apr 18, 2016 1:28 am
Thanks. I had not thought of checking the logs. There I found:
AntiVir has detected 'HEUR/APC (Cloud)' in the file C:\Users\Richard\Downloads\Setup_MakeMKV_v1.9.10.exe
I am running Avira antivirus.
When I scan Setup_MakeMKV_v1.9.10.exe with Avira, it detects nothing, but when I try to run the setup I get the above message.
The FAQ you referred me to suggests turning on "Log debug messages" but I do not know how to do this for the setup file.
Before I contacted the bulletin, I tried running Setup in Admin mode. I hope I did not let anything loose in my system. I will run a virus scan tonight.
Suggestions on how to proceed?
Thank you again for your first suggestion.
Post by Woodstock » Mon Apr 18, 2016 1:34 am
See: http://makemkv.com/forum2/viewtopic.php?f=1&t=14485
Avira is giving a false-positive, and it's keeping Windows from installing the program.
