Make MKV told me I'm outdated and to update
mattr1111
Post by mattr1111 » Wed Apr 13, 2016 10:50 pm
I have tried to update MakeMKV on 2 machines and get the same error on both machines. Have been using it for months until today. Has it been locked down, or is the version checker not correct?
marcsdesign
Re: Make MKV told me I'm outdated and to update
Post by marcsdesign » Wed Apr 13, 2016 11:08 pm
I am having the same problem. The new version won't install until I uninstall the old version... which I did (multiple times). Hopefully this will be fixed shortly.
walleye438
Post by walleye438 » Wed Apr 13, 2016 11:59 pm
Same here had 1.9.9 and new download is same what gives????
josewuzhawk
Post by josewuzhawk » Thu Apr 14, 2016 1:24 am
well glad im not the only one now
Post by Woodstock » Thu Apr 14, 2016 1:39 am
Strange how there are over a half-dozen separate threads on this exact problem on the first page of the General MakeMKV discussion forum, complete with answers on how to fix it, and no one in THIS thread noticed any of them...
marcsdesign
Post by marcsdesign » Thu Apr 14, 2016 1:46 am
I already saw that page. I don't see where it addresses the problem we are discussing.
Updated: The link in your first message went to a page I had seen. I went back to the main message board and found a possible fix that I'm going to try now. For those reading this, it says to enter this: T-s3SN8ux5qQlNBylE3l1GXnsJaLJoU7VFlM7k0SUSKA7qABr4t9DUwqHUMmV0DUT7QY.
Yep, it works!
Mkvern
Post by Mkvern » Thu Apr 14, 2016 2:18 am
Thank you! (Mac OS X)
It works!...but gives an error message on exit:
Any idea?
Update
I uninstalled completely (I think) and same error message.
1-Moved app to trash
2-Removed all MakeMKV related files: Search all related files w/EasyFind - went to each file in Finder - Deleted them all - Forced to empty trash using Onyx
3- Restarted Mac
4- Installed fresh MakeMKV
5- Applied provided key, here
6- Works (it opens but haven't tested it farther than that)
7- Same error message shows up at quitting the app (MakeMKV)
....I wonder
(Mac OS X)
marcsdesign
Post by marcsdesign » Thu Apr 14, 2016 2:30 am
I didn't get that error message. Maybe restart. Good luck.
nivix
Post by nivix » Thu Apr 14, 2016 7:41 am
I am getting the same (version outdated) error. Replacing my bought key with the key provided above doesn't solve the problem..... Any ideas?
BestRip
Post by BestRip » Thu Apr 14, 2016 11:44 am
For me the above code worked fine.
I had just reinstalled MakeMKV and it was waiting for the key. I'm running windows 7.
Thanks for making it available!
BestRip
nivix
Post by nivix » Thu Apr 14, 2016 1:30 pm
It seems to work for the graphical version but not for cli (makemkvcon)
Cotton
Post by Cotton » Thu Apr 14, 2016 2:44 pm
Hi, I'm new to this forum and have been using MakeMKV for a long time. It's the best i have ever found but after installing latest version as required, I'm still getting the same message that this version is obsolete. I see some people say they found a solution but I tried copying and pasting the Key into the register field but it's invalid. Please someone help. I'm running Windows 10 Pro and it's up to date as well.
My bad. I copied the period at the end of the registration key which gave me an invalid key. I retried without the period at the end and All is well now.
Post by Woodstock » Thu Apr 14, 2016 3:58 pm
Set your system date to 3/25/2016. Start MakeMKV. Reset your system date to today.
Now you should be able to update the key to the one found here: http://makemkv.com/forum2/viewtopic.php?f=5&t=1053
nivix
Post by nivix » Thu Apr 14, 2016 6:25 pm
So am I right that this bug also affects the payed licenses? I bought a license to go for the long term solution, I don't want to run into the same issue again when the key mentioned above expires again.
Post by Woodstock » Thu Apr 14, 2016 6:51 pm
If you have a permanent license key installed, it should not say "out of date" because of the license.
It WILL remind you if there is a newer version of MakeMKV available, but it won't stop running because of it.
