makemkvcon: setting readRetryCount?
ordually
Post by ordually »
Using makemkvcon (1.9.9 registered), what is the means for setting read retry count?
I tried adding it to /usr/share/MakeMKV/default.mmcp.xml:
<mkvSettings
        ignoreForcedSubtitlesFlag="true"
        useISO639Type2T="false"
        setFirstAudioTrackAsDefault="true"
        setFirstSubtitleTrackAsDefault="true"
        setFirstForcedSubtitleTrackAsDefault="true"
        insertFirstChapter00IfMissing="true"
        readRetryCount="25"
But I'm not sure it's having an effect.
Thanks.
MrVideo
Re: makemkvcon: setting readRetryCount?
Post by MrVideo »
IIUI correctly, it means the number of times it will retry reading a bad sector on the media. Once it as gone thru 25 (your setting) attempts, it will bail.
ordually
Post by ordually »
Agreed, that is what the parameter should do. It's available in the preferences in the GUI. But how to set it for makemkvcon?
MrVideo
Post by MrVideo »
Sorry, that I do not know.
For Windows and OS X, if you set the retry count in the GUI, it affects the command line settings. I don't know if does on Linux, though.
Do you have the GUI installed?
