Spectre DVD Won't Open
curionenj
Post by curionenj »
I can't open the Spectre DVD. This is my log.
MakeMKV v1.9.9 win(x64-release) started
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A40..03F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A40..07F to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A40..0BF to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - NO SENSE:NO ADDITIONAL SENSE INFORMATION' occurred while issuing SCSI command A40..0FF to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at |tkt#-Oit[C]HqNk5:29394781
DEBUG: Code 0 at |tkt#-Oit[C]HqNk5:29395241
Drive DVD-ROM HL-DT-ST DVD-ROM GDR8084N 1.01 has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Title #1 was added (28 cell(s), 2:22:11)
Title #2 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4/1 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 4 at 'Zc3c~QytU!#L:213132422
DEBUG: Code 0 at ,dGc:@E;98*9Mn?3z[:213140633
DEBUG: Code 0 at E`@8++Oz>~@uBb%c:121271548
DEBUG: Code 0 at E`@8++Oz>~@uBb%c:121265798
DEBUG: Code 0 at E`@8++Oz>~@uBb%c:29403866
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '4096'
DEBUG: Code 101019395 at m\<}c9ZOfCO[p%-X"m:121262969
DEBUG: Code 1 at g$sQ51kRNO#cSCw!:213130789
DEBUG: Code 0 at xkV/~z<4Pz@G%x>:121270927
DEBUG: Code 0 at #D!)I5H~^~oS5W:29398530
It seems I have a region error? VLC can play the disk with no problems, if that helps.
Many thanks!
Re: Spectre DVD Won't Open
You certainly have some error messages I haven't seen before... Like the "No Sense" error.
A Google search for "GDR8084N" shows that there is a firmware update that is applicable to your drive. It probably would not affect your issue, though.
I have drives that give the "RPC cannot be bypassed" warning, but work just fine on "out of region" disks. But MakeMKV has to have control of the drive to do that - Does it respond any differently if you do not load the disk until AFTER MakeMKV is running?
