Unable to rip Ant-Man Blu Ray
therustysaw
Post by therustysaw » Wed Apr 13, 2016 2:00 am
Report as follows
MakeMKV v1.9.9 darwin(x86-release) started
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-8A8 HA13d" opened in OS access mode.
Optical drive "BD-RE MATSHITA BD-MLT UJ260AF 1.00d" opened in OS access mode.
File 00800.mpls was added as title #0
Title #00210.mpls has length of 874 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00020.mpls has length of 166 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title 00801.mpls is equal to title 00800.mpls and was skipped
Title #00050.mpls has length of 0 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00051.mpls has length of 0 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00052.mpls has length of 0 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00070.mpls has length of 5 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00071.mpls has length of 10 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00072.mpls has length of 10 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00090.mpls has length of 5 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00060.mpls has length of 8 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00061.mpls has length of 8 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00062.mpls has length of 8 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00230.mpls has length of 519 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00091.mpls has length of 5 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00220.mpls has length of 552 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00021.mpls has length of 166 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00022.mpls has length of 166 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00006.m2ts has length of 29 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00005.m2ts has length of 0 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00029.m2ts has length of 93 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00030.m2ts has length of 73 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00007.m2ts has length of 0 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00135.m2ts has length of 0 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00136.m2ts has length of 0 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00137.m2ts has length of 0 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00139.m2ts has length of 8 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00140.m2ts has length of 8 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00141.m2ts has length of 8 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00143.m2ts has length of 5 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00144.m2ts has length of 5 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00145.m2ts has length of 5 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00146.m2ts has length of 5 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00301.m2ts has length of 205 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00302.m2ts has length of 96 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00303.m2ts has length of 162 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00306.m2ts has length of 874 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00307.m2ts has length of 486 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00308.m2ts has length of 81 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00309.m2ts has length of 109 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00310.m2ts has length of 156 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00311.m2ts has length of 205 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00312.m2ts has length of 191 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00318.m2ts has length of 5 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00319.m2ts has length of 5 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00320.m2ts has length of 5 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00321.m2ts has length of 135 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00322.m2ts has length of 145 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00323.m2ts has length of 32 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00325.m2ts has length of 31 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00326.m2ts has length of 22 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00327.m2ts has length of 31 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00328.m2ts has length of 40 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00329.m2ts has length of 24 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00330.m2ts has length of 98 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00331.m2ts has length of 79 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/WD External 2TB/Movies/Movies
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00300.m2ts' at offset '14336980992'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '14336980992'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '14336983040'
Failed to save title 0 to file /Volumes/WD External 2TB/Movies/Movies/MARVEL'S_ANT-MAN_-_BLU-RAY_t00.mkv
0 titles saved, 1 failed
Re: Unable to rip Ant-Man Blu Ray
Post by Woodstock » Wed Apr 13, 2016 4:18 am
Your drive is having problems reading part of the disk. It is possible that it is a power issue; Were you on battery power at the time?
therustysaw
Post by therustysaw » Wed Apr 13, 2016 10:14 am
Yea, I saw that it said it was a scsi hardware error. No, I wasn't on battery power, I use an OWC R/RW Drive that has 2 USB plugs, I make sure that both are plugged into the computer as one plug is for power.
I was ripping before and after Ant-Man with no problems. Tried it again after successfully ripping a couple others, I get the same error.
I've ripped about 80 Blu Rays without a problem. Just this one.
Post by Woodstock » Wed Apr 13, 2016 1:47 pm
Unfortunately I can't do any tests on Ant Man as I don't own it. As a Disney release, it would be uncommon for it to have deliberately obscure copy protection.
Even if the disk appears clean, a wipe-down might "fix" it.
Incidentally, your drive shipped from the warehouse about 1.5 miles south of me... :)
bravesbaseball17
Post by bravesbaseball17 » Thu Nov 14, 2019 1:21 am
Man I'm super late to this party, but any luck getting this bd to rip? I've tried three different copies, none of them will work.
