DTS will not play
NicoD
DTS will not play
#1 Post by NicoD » Thu Apr 22, 2010 3:26 pm
I rip my DVD's with MKV and choose DTS as audio.
Allthough my mediaplayer (Medi8er) shows DTS 6 channels I only get 2 channels to hear through my Denon a/v which shows 2 channels as source.
What can I do to correct this?
Tx
Nico
Westie69
Re: DTS will not play
#2 Post by Westie69 » Mon Apr 26, 2010 7:22 pm
if you have your amp connect to your pc i had a simular problem i solved it by whilst playing an mkv (i use ffshow with Windows media play) i right clicked on the blue ffshow icon and uder settings some where there is a tick box for dts and ac3 tick them both and restart windows media player hopefuly thats should now show up on your amp dts/dolby as long as your amp is set on auto.
