LG BR/HD Combo Drive Not Useable after entering beta key
djryanj
#1 Post by djryanj » Sun Apr 25, 2010 11:08 pm
Grabbed 1.5.4 beta shareware, and it read my drive just fine. As soon as I "registered" with the beta key from the forums, the program began saying "no usable drives found".
Uninstalling and reinstalling made the drive visible again - but I haven't tried to re-enter the beta key.
The program is reporting my drive as the following:
HD-DVD-ROM HL-DT-ST BDDVDRW GGC-H20L 1.02
Thank you.
Krobar
Re: LG BR/HD Combo Drive Not Useable after entering beta key
#2 Post by Krobar » Mon Apr 26, 2010 12:03 am
I have this drive and did not have an issue with the beta key. Try upgrading to firmware 1.03 (The latest), you might want to use mediacodeedit to unlock fullspeed ripping too.
#3 Post by mike admin » Mon Apr 26, 2010 7:49 am
djryanj wrote:Uninstalling and reinstalling made the drive visible again - but I haven't tried to re-enter the beta key.
Make sure the you launch MakeMKV as administrator, right click on the icon, select "Run as administrator".
djryanj
#4 Post by djryanj » Mon Apr 26, 2010 6:58 pm
Thanks to you both, I'll give them both a shot...
-r-
