Top Cat Region 1
Edworld
Top Cat Region 1
Post by Edworld »
Having issues with Disc 4 which is a flipper on title 5 of both sides (episode 23 and 29), below is the log:
Disc is new and no finger prints
Debug log started at Sat Apr 09 02:39:18 2016 , written by MakeMKV v1.9.9 win(x64-release)
001005:0000 MakeMKV v1.9.9 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Kodi/MakeMKV_log.txt
003019:0000 Cells 7-end were skipped due to cell commands (structure protection?)
003028:0000 Title #1 was added (6 cell(s), 2:33:32)
Title skip vts=1 pgcn=1 hash=A92FDC743BFB904E
003028:0000 Title #2 was added (1 cell(s), 0:25:35)
003028:0000 Title #3 was added (1 cell(s), 0:25:36)
003028:0000 Title #4 was added (1 cell(s), 0:25:34)
003028:0000 Title #5 was added (1 cell(s), 0:25:33)
003028:0000 Title #6 was added (1 cell(s), 0:25:37)
003028:0000 Title #7 was added (1 cell(s), 0:25:37)
003025:0000 Title #9 has length of 21 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #9/1 has length of 11 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #9/2 has length of 66 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #9/3 has length of 29 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #10 has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #11 has length of 23 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #12 has length of 51 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #13 has length of 403 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #14 has length of 185 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #15 has length of 49 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #16 has length of 49 seconds which is less than minimum title length of 600 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory F:/New Movies
001003:0020 DEBUG: Code 3221225628 at ~a>#F;zC~?ZK*A(;gy0$qXr5>:213131732
001003:0020 DEBUG: Code 3221225628 at ?w!|R]:)Y2.z$@Q+:29393953
001003:0020 DEBUG: Code 100864261 at #8ZaNU.{RP#\,ecY:121269731
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '546963456'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '546963456'
DEBUG: Code 3221225628 at m\<}c9ZOfCO[p%-X"m:213130904
001003:0020 DEBUG: Code 3221225628 at m\<}c9ZOfCO[p%-X"m:121262969
DEBUG: Code 100864261 at m\<}c9ZOfCO[p%-X"m:213130904
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '547049472'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '547049472'
001003:0020 DEBUG: Code 100864261 at m\<}c9ZOfCO[p%-X"m:121262969
001003:0020 DEBUG: Code 0 at ^sn-7'9lk#*zI%}tr!g-:121263291
001003:0020 DEBUG: Code 0 at ^EJq*Sm!!u(A7_]$zR/:121261750
001003:0020 DEBUG: Code 0 at ^sn-7'9lk#*zI%}tr!g-:213130812
001003:0020 DEBUG: Code 267114 at ^sn-7'9lk#*zI%}tr!g-:29393286
001003:0020 DEBUG: Code 0 at 4W~5;,qVF!rkp['%ZSgF\:29398967
005003:0000 Failed to save title 5 to file F:/New Movies/TOP_CAT_SEASON_1_DISC_4_SIDE_A_t05.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sat Apr 09 02:51:36 2016
Re: Top Cat Region 1
It would appear that there are two primary spots where the drive is having trouble reading the disk (the uncorrectable errors), and a few more where it is sending a "best guess" at what the data is (where the debug messages are). The first is eventually read after several retries, but MakeMKV hit the end of its retries before a good copy of the data at the second could be read.
I would suggest cleaning the disk and trying again.
Edworld
Post by Edworld »
I cleaned the disc both sides and still was unable to rip, I am thinking that it is a faulty disc
