Basic Blu-Ray Burning
Tyrone787
Post by Tyrone787 »
I am new here. If my DVD drive on my laptop cannot read Blu-Ray discs, how can I burn a Blu-ray disc? Can I connect my stand alone Blu-ray player & connect it to a USB drive on my laptop? If I do this, will the laptop recognize the Blu-ray player?
smares
Re: Basic Blu-Ray Burning
Post by smares »
No, you need a Blu-ray drive. Either an external one you can connect via USB, or an internal one to replace your DVD drive in the laptop.
Reading Bluray disks requires a Bluray reader; burning them requires a Bluray burner.
MakeMKV only requires the reader, because it does nothing with burning disks. There are lots of BD-capable readers out there for laptops.
MrVideo
Post by MrVideo »
Tyrone787 wrote:Can I connect my stand alone Blu-ray player & connect it to a USB drive on my laptop? If I do this, will the laptop recognize the Blu-ray player?
As pointed out, you can't. You wouldn't even be able to find a cable that would allow you to do that. Both the laptop and Blu-ray player are USB hosts. You cannot connect USB hosts together.
