My Best Friends Girl DVD
Spappy
Post by Spappy » Sat Apr 02, 2016 4:22 am
First time posting, please correct me if my pasted portion of the log is not adequate.
002003:0000 Error 'OS error - The I/O device reported an I/O error' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '0'
DEBUG: Code 3221225861 at u@zsSvoO4Pu.6'>]#4:213130904
002003:0000
Thank you!
Re: My Best Friends Girl DVD
Post by Woodstock » Sat Apr 02, 2016 1:11 pm
Is this an external drive, or internal? The operating system is reporting that the drive is off-line when it tries to read from it, which is unusual so early in a rip. But the error is just ambiguous enough that it could be a problem with reading part of the disk, rather than being off-line.
Two things to try - clean the disk, and reset your computer. The reset is to make sure that the drive and operating system are talking to each other properly.
Spappy
Post by Spappy » Wed Apr 06, 2016 1:30 am
Internal drive. Disk has been cleaned, computer rebooted.
Now I get the following error:
Error 'Scsi error - ILLEGAL REQUEST:COMMAND SEQUENCE ERROR' occurred while issuing SCSI command A30..00CC3000A0..05AD773B1B10..0 to device 'SPTI:\Device\CdRom1'
Drive DVD+R-DL HL-DT-ST DVD+-RW GSA-H31N B109 has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
Any thoughts?
Thank you!
Post by Woodstock » Wed Apr 06, 2016 3:35 am
It is strange that an LG drive (Dell OEM branded, though) would report a problem with region locking... None of my LGs does that.
Do you know if the drive has ever had its firmware upgraded? A google search for "GSA-H31N B109" came up with at least two firmware patches since the drives were discontinued.
