Hunger Games Mockingjay Part 2 (Red Version)
JoeDoe
#1 Post by JoeDoe » Wed Mar 23, 2016 6:11 pm
"RED" Version ONLY---VERIFIED!
00428.mpls
I watched the entire original blu-ray on my set top player and watched the "ripped" MKV side by side for the entire movie. This IS the correct playlist for "Red" version. This is only verified for "Red" version other releases (US, Netflix, etc) will probably differ.
Name: Hunger Games: Mockingjay Part 2
Source file name: 00428.mpls
Duration: 2:16:57
Chapters count: 16
Segment count: 20
Segment map: 515,511,506,519,513,516,517,503,518,520,505,509,510,514,508,501,502,504,507,512
File name: Hunger_Games_Mockingjay_Part_2_t119.mkv
TwinSkippy
Re: Hunger Games Mockingjay Part 2 (Red Version)
#2 Post by TwinSkippy » Sat Mar 26, 2016 5:17 pm
Agree.
Zonian
#3 Post by Zonian » Tue Mar 29, 2016 4:20 am
Awesome guys, tyVm!
Is there another method we can use since the procmon is no longer working besides watching them side by side? With my 6 yr old twin boys and heck even the 15 yr old girl! It's absolutely imperative that I back up everything I buy! NO ONE is allowed to watch/listen to anything until I have made a copy... yes, they ARE that bad! lol
terrykuntz
#4 Post by terrykuntz » Tue Mar 29, 2016 3:21 pm
I tried playlist 428 for my red version and it didn't work for me. The video skips frames and the audio is way out of sync. Could there be 2 different red versions out there?
isuzudave
#5 Post by isuzudave » Tue Mar 29, 2016 11:46 pm
428 worked for my "red" version. I watched it side by side with the BD and it was the same.
MrVideo
#6 Post by MrVideo » Wed Mar 30, 2016 1:46 am
terrykuntz wrote:I tried playlist 428 for my red version and it didn't work for me. The video skips frames and the audio is way out of sync. Could there be 2 different red versions out there?
An audio out-of-sync issue is something on your end. None of the fake playlists have audio out-of-sync, because the M2TS files are used within the play list that is correct.
mrtumnus
#7 Post by mrtumnus » Fri Apr 01, 2016 3:35 am
I tried ripping 428, but got the following error. Can someone confirm if this is a problem with the disc itself? I tried increasing the read error limit to 99, but it still happens.
Saving 1 titles into directory C:/Users/ellio/Videos/Ripped
DEBUG: Code 0 at n7~l+lH59WZ+0;g$ai?L:121262647
The source file '/BDMV/STREAM/00503.m2ts' is corrupt or invalid at offset 203710464, attempting to work around
Hash check failed for file 00503.m2ts at offset 203876352, file is corrupt.
DEBUG: Code 2 at n7~l+lH59WZ+0;g$ai?L:121263314
DEBUG: Code 183 at n7~l+lH59WZ+0;g$ai?L:121264510
The source file '/BDMV/STREAM/00503.m2ts' is corrupt or invalid at offset 203857920, attempting to work around
DEBUG: Code 450 at OWEwm?s~G<=ZwAh-FDS:121268075
DEBUG: Code 0 at 4W~5;,qVF!rkp['%ZSgF\:29398967
DEBUG: Code 0 at u]\2oU~M}Pdu:s=e{:213131893
DEBUG: Code 0 at u]\2oU~M}Pdu:s=e{:121263406
DEBUG: Code 0 at u]\2oU~M}Pdu:s=e{:29393907
AV sync issue in stream 0 at 0:09:33.281 : video frame timecode differs by +41.7ms
Failed to save title 118 to file C:/Users/ellio/Videos/Ripped/Hunger_Games_Mockingjay_Part_2_t118.mkv
0 titles saved, 1 failed
#8 Post by Woodstock » Fri Apr 01, 2016 1:40 pm
Yes, the error messages you are getting are consistent with a dirty or scratched disk.
