Defragging - Splitting
pdlmb
Post by pdlmb » Tue Apr 20, 2010 3:22 am
Have used makeMKV to backup my BD collection to a HDD for use via a WD TV Live media player.
This generally works very well, but occasionally I get "breakup". I read that defragging is the answer.
However this operation takes 2 days on my 1 TB BD HDD ! Even having 25% free space does not appreciably shorten the defrag time.
Have used both Piriform Defraggler and Uniblue DiskRescue.
Any suggestions ? Is there a "Splitter" software available which will aid the defrag speed without upsetting the BD playback ?
TIA, Peter
crowfax
Re: Defragging - Splitting
Post by crowfax » Tue Apr 20, 2010 5:08 pm
I've found that O&O Defrag is the best tool. This is a personal opinion and subjective of course - I've done no scientific testing between available tools (however I have used many).
If you try it, deselect the "zones" button (for your data hard drive, if you choose to defrag your system with it the "zones" option is excellent) and then tell it to use the "stealth" defrag option. It's the fastest and should be done quite rapidly with your drive.
Good luck!
MilesAhead
Post by MilesAhead » Fri Apr 23, 2010 7:15 pm
Peter, is this HD internal or external?
I have WD HDTV for USB and USB 2.0 drives take forever to defrag. But recently I got a USB 3.0 card and a couple of Sharkoon USB 3.0 docking stations. The WD drives I stick in the docks function probably faster than if I installed them internally. I use Puran Defrag with the optimizations deselected.
I use a USB 2.0 docking station as input to the WD player.
I'm hoping the next WD player will support USB 3.0 because USB 2.0 is just too slow.
pdlmb
Post by pdlmb » Sun Apr 25, 2010 2:04 am
Thanks for your replies. I shall try both O & O and PURAN. Agree that USB2 is slow, I now use ASTONE 3.5" HDD cases with eSata. near 3 times faster and tests by others suggest it beats USB3. Peter
