From backup file -- Failed to open disk; DBG ASSERT;
bluebear
Post by bluebear »
"Failed to open disk" while trying to open a decrypted hard drive backup copy of Harry Potter Deathly Hallows Part 1.
Running Mac OS X version 10.9.5 on a 17" MacBook Pro that was new in February, 2011.
Unable to add the log file to this post. Apparently the board attachment quota has been reached.
[color=#0000FF]Debug log started at Fri Mar 25 01:35:37 2016 , written by MakeMKV v1.9.9 darwin(x86-release)
001005:0000 MakeMKV v1.9.9 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/makemkv/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL MATSHITA DVD-R   UJ-898 HE13" opened in DASPI v1.5 mode.
001003:0020 DEBUG: Code 0 at 0j1](fisv4`[Nl9k&BkEw+'&/:213131318
003006:0000 Opening files on harddrive at /Volumes/Backup/H/HARRY_POTTER_7_DEATHLY_HALLOWS_1
001003:0020 DEBUG: Code 4 at mcF`nY%ltak.@:213130122
001003:0020 DEBUG: Code 0 at @Utb;KHS|/qrh+u5|:29394873
001003:0020 DEBUG: Code 0 at wljq#HBn+8I}'4x7:29398461  [This line repeated many times]
001003:0020 DEBUG: Code 11 at wljq#HBn+8I}'4x7:121267477
001003:0020 DEBUG: Code 13 at wljq#HBn+8I}'4x7:121267477
001003:0020 DEBUG: Code 14 at wljq#HBn+8I}'4x7:121267477
001003:0020 DEBUG: Code 17 at wljq#HBn+8I}'4x7:121267477
001003:0020 DEBUG: Code 18 at wljq#HBn+8I}'4x7:121267477
001003:0020 DEBUG: Code 19 at wljq#HBn+8I}'4x7:121267477
001003:0020 DEBUG: Code 20 at wljq#HBn+8I}'4x7:121267477
001003:0020 DEBUG: Code 22 at wljq#HBn+8I}'4x7:121267477
001003:0020 DEBUG: Code 52 at wljq#HBn+8I}'4x7:121267477
001003:0020 DEBUG: Code 100 at wljq#HBn+8I}'4x7:121267477
001003:0020 DEBUG: Code 120 at wljq#HBn+8I}'4x7:121267477
DISCID=1ADC95BEBE9EEA8C112D40CD04AB7A8D75C4F961
001001:0020 DBG ASSERT: A"DP(P>@'H:=G/hy"0l!O?+gzl$ at htQ|e$h-+VbnE1#Y$Hjur:121261957
[/color]
Re: From backup file -- Failed to open disk; DBG ASSERT;
Mike will have to decode what the debug messages mean. Fastest way to have that happen is to send the files asked for in the FAQ listed in my signature, including the whole log file, to support@makemkv.com .
bluebear
Post by bluebear »
Thanks. I emailed the file Harry_Potter_Deathly_Hallows_1.tar.gz to support (at) makemkv.com
I am wondering whether the files are somehow corrupted or were not decrypted when they were written to the backup drive. Therefore I will rip the files again from the Blu-ray disc over the weekend.
MakeMKV would not really care if they were encrypted or not, if it did the original backup... But corruption is another issue. :)
bluebear
Post by bluebear »
Yes, the original backup had been created by an older version of MakeMKV on May 11, 2011. I am not having any problems with other backups on that hard drive.
The current version 1.9.9 of MakeMKV was able to create a new backup from the Blu-Ray disc, and also opened that backup without any problems.
