Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : No
Format settings, Matrix : Custom
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Duration : 23mn 18s
Bit rate mode : Variable
Bit rate : 6 131 Kbps
Maximum bit rate : 9 800 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 24.600 fps
Original frame rate : 29.970 (30000/1001) fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.721
Time code of first frame : 00:59:58;00
Time code source : Group of pictures header
Stream size : 1 023 MiB (97%)
Title : MPEG-2 480i NTSC 1.33:1
Language : English
Default : Yes
Forced : No
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
DVD Troubles
angelgraves13
DVD Troubles
So I've noticed that MakeMKV has been making my DVD rips as "variable frame rate" instead of constant, and with an unmatching frame rate. Should I worry that it was copied incorrectly?
Re: DVD Troubles
What did you use to generate the report?
There are several tools that declare the standard rates "variable" because they do not give exact inter-frame times. The "jitter" is considered "variable frame rate", even though it is impossible for them to always be truly constant.
angelgraves13
Re: DVD Troubles
MPC BE Nightly is reporting more and more files as variable, but it seems it's just the bundled version of mediainfo.
Re: DVD Troubles
MediaInfo is one of the programs that I've read reports of "variable" when the rate is actually "fixed".
