The Hunger Games Mockingjay Part 2 2015 US Release Blu-ray
billbillw
Re: The Hunger Games Mockingjay Part 2 2015 US Release Blu-r
#16 Post by billbillw » Wed Mar 23, 2016 1:20 am
gamecaptor wrote:I found it to be 00821.mpls using process monitor for the Redbox version.
I agree with this. I used the latest version of DVDFab and it picked 821.
scamon
#17 Post by scamon » Wed Mar 23, 2016 1:37 am
Dvd fab is inconclusive
MustangChris04
#18 Post by MustangChris04 » Wed Mar 23, 2016 2:58 am
There is no way the redbox title is 258 or 821. dvdfab picked up 821 but it is not correct. The first scene leading up to the title of the movie is butchered.
The Bear Jew
#19 Post by The Bear Jew » Wed Mar 23, 2016 3:20 am
I have been struggling with the redbox version as well. I tried 980 bc i misread the process monitor. I've also tried 821, 510 & 600, all incorrect.
rs182
#20 Post by rs182 » Wed Mar 23, 2016 3:36 am
Another vote for 428 on the Redbox version.
I ripped 428, 258, and 821. 258 & 821 are definitely not the correct titles.
Although I haven't watched title 428 all the way through (haven't even seen the movie yet), the scene & audio transitions seem to be correct for the first half of the movie.
troyBORG
#21 Post by troyBORG » Wed Mar 23, 2016 4:53 am
428 is the Redbox version!
I ripped the whole disc to the HDD so I could play the mpls files along side the Blu-Ray, I checked each chapter, and they all line up.
Title information
Name: Hunger Games: Mockingjay Part 2 (English)
Source file name: 00428.mpls
Duration: 2:16:57
Chapters count: 16
Segment count: 20
Segment map: 515,511,506,519,513,516,517,503,518,520,505,509,510,514,508,501,502,504,507,512
File name: Hunger_Games_Mockingjay_Part_2_t118.mkv
superdave0629
#22 Post by superdave0629 » Wed Mar 23, 2016 5:12 am
mrdamour wrote:Any idea what the right title is on the Netflix version?
For the Netflix version, I found 00600.mpls had the right sequence:
Title information
Source file name: 00600.mpls
Duration: 2:16:57
Chapters count: 16
Segment count: 20
Segment map: 515,513,516,519,511,506,517,503,520,518,505,509,514,510,508,501,502,507,504,512
File name: Hunger_Games_Mockingjay_Part_2_t170.mkv
darknite
#23 Post by darknite » Wed Mar 23, 2016 6:12 am
I have the US retail BLU-RAY + DVD + DIGITAL HD combo pack from Best Buy
MakeMKV gives me a choice of 2 files, a 10.6 GB file with 8 chapters, and a 28.5 GB file with 16 chapters
I ripped the 28.5 GB file, which is reported as
Title information
Source file name: 00628.mpls
Duration: 2:16:57
Chapters count: 16
Segment count:1
Segment map: 501
File name: Hunger_Games_Mockingjay_Part_2_t01.mkv
So really, like the walmart disc, seems like only one viable file. I have not played the rip side by side with the Blu-Ray to confirm
RickInHouston
#24 Post by RickInHouston » Wed Mar 23, 2016 12:51 pm
258 is wrong - second chapter doesn't match up.
600 and 428 play similar to the bluray when played next to each other and skipped to each chapter.
Segment maps don't match but they play the same. The time each chapter starts looks to be pretty much the same. I didn't check that for exactness.
risone01
#25 Post by risone01 » Wed Mar 23, 2016 1:10 pm
It would seem in a lot of cases most every version of a particular title found at Netflix, Red, Retail and rental store versions, vary in some way. Lionsgate disks are always challenging. Using PowerDVD and Process Monitor, I discovered that the actual MPLS being used by PowerDVD was written to a directory on my computer. A file of the same name (0258.mpls) exists on the original Disk but they were NOT the same. I opened the computer written version in Notepad and despite seeing a bunch of hieroglyphics, the actual stream (segment) file names can be plainly seen in the proper sequence. Using that sequence, I compared it to every segment map shown in Makemkv until I found the one that matched. In my case that was 0600.mpls.
As with everything else in life, your results may vary. Good Luck!
RickInHouston
#26 Post by RickInHouston » Wed Mar 23, 2016 4:15 pm
I confirm with risone01. Wow, how did anyone figure that out!
The last line in process monitor points to a file called 258. You open that file and it starts with MPLS0200 and then goes on to list the correct parts in order for playlist 600. Why does that string start with playlist 200 which doesn't even exist? I find that curious.
Great work, risone01.
MrVideo
#27 Post by MrVideo » Wed Mar 23, 2016 4:19 pm
StarLord wrote:Guys, I just picked up the US Wal-Mart retail copy and found it to only have one available file as follows:
Title information
Duration: 2:16:57
Chapters count: 16
Segment count: 1
Segment map: 501
File name: Hunger_Games_Mockingjay_Part_2_t09.mkv
There are two tricks for getting sections of the movie out-of-order. One is to have many M2TS files and have a lot of play lists that play the movie out-of-order by listing the M2TS files out-of-order. The second is to have a single M2TS file and have a lot of play lists that have many entry points into the single file. With the second method, you can tell if the playlist is bad because it will have many entry points and they won't be in sequence. A correct playlist will only list the M2TS file once and it will cover the whole movie. If you don't use the PowerDVD/process monitor method, then you have to use BDEdit to look at all of the play lists, looking for the ones that only list the single M2TS file.
gereral1
#28 Post by gereral1 » Wed Mar 23, 2016 5:54 pm
risone01 wrote:It would seem in a lot of cases most every version of a particular title found at Netflix, Red, Retail and rental store versions, vary in some way. Lionsgate disks are always challenging. Using PowerDVD and Process Monitor, I discovered that the actual MPLS being used by PowerDVD was written to a directory on my computer. A file of the same name (0258.mpls) exists on the original Disk but they were NOT the same. I opened the computer written version in Notepad and despite seeing a bunch of hieroglyphics, the actual stream (segment) file names can be plainly seen in the proper sequence. Using that sequence, I compared it to every segment map shown in Makemkv until I found the one that matched. In my case that was 0600.mpls.
I will have to check this movie out with my methods to see if you are referring to screen pass cashed protection which can be defeated with my alldup video and process monitor via powerdvd 14 or 15. The last lions gate movie used a hidden playlist file that was called 209.mpls which linked to 256.mpls for insurgant. Same crap... If you guys are not sure about how to do this please check out hometheater 101 playlist on YouTube under my channel. Google my name and it will come up. I've helped thousands of users figure this out. If it's new I'll definitely expose it. Google my name for mplsfinder as well as Rotty and I designed a tool that does exactly alldup does and will reveal the correct playlist even if it's hidden or not. Can weed out thousands of mpls files in 3 sec as the program loads every mpls memory and can check segment maps against each other as well as hidden file mpls by comparing the hidden byte data with actual byte data in the correct file. Alldup and processor monitor were originally my ideas. Peace out..
bq1533
#29 Post by bq1533 » Wed Mar 23, 2016 9:33 pm
I, too, played the Redbox Blu-ray alongside 428 and it lined up perfectly.
Captain Pariah
#30 Post by Captain Pariah » Thu Mar 24, 2016 12:13 am
Title information
Duration: 2:16:57
Chapters count: 16
Segment count: 20
MY Netflix version came out to 428.
