is there a way when using direct Blu-ray playback with VLC
bk7777
Post by bk7777 » Tue Mar 22, 2016 5:52 am
Is there a way to get more diag data from makemkv or VLC when using direct playback with VLC?
Something like what #####.mpls file is in use
or
segment map
anything that would provide a direction.
Re: is there a way when using direct Blu-ray playback with V
Post by Woodstock » Tue Mar 22, 2016 2:35 pm
If you're hoping for something to tell you which play list is the correct one to rip, probably not to that level. You can turn on debug logging in MakeMKV, and open the Information screen in VLC, but that is about the maximum.
