Problems with Captain America - Winter Soldier
Fndr70
I'm having trouble with this disc. Whenever I try to make the mkv file, it gets about half way through then I get a fatal error. Here's the log below. I've had this same problem on two discs of this movie now.
MakeMKV v1.9.8 win(x64-release) started
The new version 1.9.9 is available for download at /download/
File 00200.mpls was added as title #0
File 00800.mpls was added as title #1
Title #00000.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00210.mpls was added as title #2
Title 00801.mpls is equal to title 00800.mpls and was skipped
Title #00052.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00091.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00084.m2ts was added as title #3
Title #00092.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00093.m2ts was added as title #4
Title #00097.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00099.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00124.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00128.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00134.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00136.m2ts was added as title #5
Title #00137.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00138.m2ts has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00140.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory F:/Video/MARVEL'S_CAPTAIN_AMERICA_THE_WINTER_SOLDIER_-_BLU-RAY
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '7399796736'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '7399796736'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '7399800832'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '7400257536'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '7400454144'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '7400454144'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '7400460288'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '7400466432'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '7400472576'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '7400484864'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '7401308160'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '7401308160'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '7403470848'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '7403470848'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '7404122112'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '7404122112'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '7404126208'
Failed to save title 1 to file F:/Video/MARVEL'S_CAPTAIN_AMERICA_THE_WINTER_SOLDIER_-_BLU-RAY/MARVEL'S_CAPTAIN_AMERICA_THE_WINTER_SOLDIER_-_BLU-RAY_t01.mkv
0 titles saved, 1 failed
Re: Problems with Captain America - Winter Soldier
First, you should update MakeMKV to the current version, but it isn't going to help with this disk:
This error sequence is usually seen when you are ripping a disk with an external, USB-powered drive, and the disk is one that MakeMKV can rip at "full speed". It is likely you saw the rip speed reaching past 4x, possibly 8x, and the drive reached the end of the available power from the USB port. At this point, the drive goes "off-line", and Windows reports the error. Sometimes, they can recover, but rarely.
If it is an external drive, make sure it has full power available to it. If you are plugging in to an external hub that doesn't have its own power supply, try plugging directly into the computer's USB ports. If the computer is a laptop, make sure it is on its charger, to make sure full power is available to the USB ports ("internal" optical drives in laptops are typically powered by the USB power supply).
Fndr70
Thanks for the reply Unfortunately though it's an internal SATA drive. I did check to make sure the power adapter is fully plugged in and it is
You said the error usually occurs when using a USB drive. Are there other (rarer) reasons this could happen?
Yes, there have been times where the error has occurred on a disk that is damaged or improperly manufactured. But the device errors that follow tend to discount that... a disk error should not cause the drive to go off-line.
pecck
Hello, I too am having an issue with this BluRay. Can someone let me know what the issue is? The disc seems to be clean and free of scratches. I'm using an iMac and an external USB Pioneer BluRay drive that runs two USB cables, one for power and the other for data. I don't have issues with other discs.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '17383944192'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '17383944192'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '17383950336'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '17383956480'
DEBUG: Code 1073741829 at N;87||f5zz=H&u>Wt_:121262969
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '17383956480'
DEBUG: Code 100864261 at N;87||f5zz=H&u>Wt_:121262969
DEBUG: Code 0 at =^M4rI33W2cx/\Cfg0*W:121263291
DEBUG: Code 0 at :Etg}tshH7JYI{stw<}i:121262302
DEBUG: Code 0 at =^M4rI33W2cx/\Cfg0*W:213130812
DEBUG: Code 8488260 at =^M4rI33W2cx/\Cfg0*W:29393286
DEBUG: Code 0 at g/>>m:Vzl/$+*U=='upDy:29398967
Failed to save title 0
yorgo
If you're not experiencing with other discs and you're certain the drive is getting enough power, see here: http://www.makemkv.com/forum2/viewtopic.php?f=8&t=15055
Help Keep MakeMKV Going - http://www.makemkv.com/buy/
Latest Beta Key - http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Multiple Playlists? - http://www.makemkv.com/forum2/viewtopic ... 6&start=15
pecck
I cleaned the disc, set retry count to 25 and verified connections. This is my latest log -
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '18437830656'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '18437830656'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '18437832704'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '18437836800'
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '18437830656'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '18437849088'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '18437867520'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '18438094848'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '18438094848'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '18451986432'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '18451986432'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '18451988480'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '18455789568'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '18455789568'
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '18456115200'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '18456379392'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '18456379392'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '18457559040'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '18457559040'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '18458148864'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '18458148864'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '18458738688'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '18458738688'
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '18458738688'
DEBUG: Code 9013056 at =^M4rI33W2cx/\Cfg0*W:29393286
angelgraves13
Change retry count to 99 under IO in Settings and try again. It may just need a few more attempts at reading to get past a sector.
yorgo
And if that fails, replace the disc.
bleph
Hi
sorry if this is obvious
i have cleaned and replaced disc x2
i have tried back up option
i have increased/changed retry
using external pioneer bdr-xs07u
disc issue or drive
it fails (at the end) - copy complete, 0 titles save, 1 failed
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '19143327744'
DEBUG: Code 100942878 at T*66mI"9R%2H!-6CI':213131502
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '19143327744'
DEBUG: Code 100864261 at T*66mI"9R%2H!-6CI':213131502
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '19143327744'
DEBUG: Code 100865282 at T*66mI"9R%2H!-6CI':213131502
DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:29395471
DEBUG: Code 0 at >u+x)D9+i6!-r0Fh7!4O:29394068
DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:213131157
DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:121262647
DEBUG: Code 9347328 at %K{3+D<I-p.W2g)K$P73:121261773
DEBUG: Code 0 at 5#w%HEc@g}P<=`%X^J>Av:213137068
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '19143327744'
DEBUG: Code 3221225628 at T*66mI"9R%2H!-6CI':213131502
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00101.m2ts' at offset '19143917568'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '19143917568'
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 1 to file E:/Video/MARVEL'S CAPTAIN AMERICA- THE WINTER SOLDIER - BLU-RAY/MARVEL'S CAPTAIN AMERICA- THE WINTER SOLDIER - BLU-RAY_t01.mkv
Encountered 1286 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
disc issue or drive
