Grimm Season 4 Disk 4
Beorn
#1 Post by Beorn » Mon Mar 14, 2016 1:36 am
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '2728587264'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '2728587264'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00802.m2ts' at offset '2735142912'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '2735142912'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '2735144960'
Failed to save title 2 to file J:/Staged/MakeMKV/Grimm_Season_Four_(Disc_4)_t02.mkv
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '7796736'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '17694720'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '18413568'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '23457792'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '23457792'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '23721984'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '25688064'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '25688064'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '27586560'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '29030400'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '29030400'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '29032448'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '30732288'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '31979520'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '31979520'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '47443968'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '67762176'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '92995584'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '92995584'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '2854877184'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '2854877184'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00803.m2ts' at offset '2880632832'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '2880632832'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '2880634880'
Failed to save title 3 to file J:/Staged/MakeMKV/Grimm_Season_Four_(Disc_4)_t03.mkv
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '6389170176'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6389170176'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '6407847936'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6407847936'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '6408960000'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '6408960000'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '6443237376'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '6443888640'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6443888640'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6443892736'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '6445006848'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '6445461504'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '6447820800'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '6450444288'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6450444288'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '6450446336'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6450446336'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '6450640896'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '6453460992'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '6454769664'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6454769664'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '6465189888'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6465189888'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '6468071424'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6468071424'
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '6468075520'
Error 'OS error - {Unknown Disk Format} The disk in drive hs is not formatted properly. Please check the disk, and reformat if necessary' occurred while reading '\Device\CdRom0' at offset '6468075520'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00804.m2ts' at offset '6468071424'
Failed to save title 4 to file J:/Staged/MakeMKV/Grimm_Season_Four_(Disc_4)_t04.mkv
2 titles saved, 3 failed
Re: Grimm Season 4 Disk 4
#2 Post by Woodstock » Mon Mar 14, 2016 1:48 am
There is something causing the disk to be unreadable reading that particular file.
Options are limited; You can try cleaning the disk and trying the rip again. However, if it is a new purchase, I'd return it for exchange.
Beorn
#3 Post by Beorn » Mon Mar 14, 2016 2:19 am
I have already replaced the disk twice. They are spotless and play fine in a Blu-ray player.
