The Hunger Games Mockingjay Part 2 2015 US Release Blu-ray
Does anyone know which is the correct playlist for The Hunger Games Mockingjay Part 2 2015 US release Blu-ray?
Re: The Hunger Games Mockingjay Part 2 2015 US Release Blu-r
Just checked, and the correct playlist is in fact 00706.mpls
Name: Hunger Games: Mockingjay Part 2
Source file name: 00706.mpls
Duration: 2:16:57
Chapters count: 16
Segment count: 18
Segment map: 510,503,517,513,520,501,519,505,504,508,506,512,509,507,514,515,516,518
Duration: 2:16:57
Chapters count: 16
Segment count: 18
What method did you use to check it?
I'll be getting the UK disk which will be different. Thanks
Red label seems to be 258. Anyone wish to confirm?
RickInHouston wrote:Red label seems to be 258. Anyone wish to confirm?
been wondering that myself - how did you confirm that?
powerdvd won't play it so I can't pull mpls.
Dvdfab said 428
None of the recommendations worked for me. After a bit of sleuthing around I determined the correct source mpls on the version I have to be 600.
Segments: 515,513,516,519,511,506,517,503,520,518,505,509,514,510,508,501,502,507,504,512
Playback of disk compared to MKV matched perfectly.
PowerDVD and Process Monitor. I confirmed three times. It's acted a bit wonky, but that's what I get.
Don't know why disc wouldn't play with your powerdvd.
risone01 wrote:None of the recommendations worked for me. After a bit of sleuthing around I determined the correct source mpls on the version I have to be 600.
What version of the disc?
I took risone01's advice and ripped 600, then matched it up with the movie chapter by chapter and it's the right one.
US retail version Dolby Digital only, no HD Audio.
Its' not 258 or 600 on the red box edition.
I found it to be 00821.mpls using process monitor for the Redbox version.
428 as stated above.
rhardy1958 wrote:Its' not 258 or 600 on the red box edition.
lol this is getting comical - so we essentially have no idea what it is
Guys, I just picked up the US Wal-Mart retail copy and found it to only have one available file as follows:
Title information
Source file name: 00628.mpls
Duration: 2:16:57
Chapters count: 16
Segment count: 1
Segment map: 501
File name: Hunger_Games_Mockingjay_Part_2_t09.mkv
Title information
Duration: 2:16:57
Chapters count: 16
Segment count: 1
Segment map: 501
Any idea what the right title is on the Netflix version?
