Lucy BD rip error
NShameA
Lucy BD rip error
#1 Post by NShameA » Fri Mar 11, 2016 6:05 pm
Hello, Is this error the disc or the MakeMKV ? Something else perhaps ? TY
File 00800.mpls was added as title #0
File 00358.mpls was added as title #1
File 00360.mpls was added as title #2
File 00371.mpls was added as title #3
Title #00018.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50355.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00300.m2ts was added as title #4
File 00301.m2ts was added as title #5
Title #00350.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00351.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00352.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00353.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00354.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00355.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00356.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00357.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00361.m2ts was added as title #6
Title #00362.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00363.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00364.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00365.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00366.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00367.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00368.m2ts was added as title #7
Saving 1 titles into directory D:/RIPS
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '8940355584'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '8940355584'
Failed to save title 0 to file D:/RIPS/Lucy_t00.mkv
0 titles saved, 1 failed
Re: Lucy BD rip error
#2 Post by Woodstock » Fri Mar 11, 2016 7:21 pm
The error sequence matches a drive going off-line during the read, due to running out of power. It CAN come from an error on the disk, but it probably isn't. If you try the rip immediately afterward, the location of the error will probably change. If it does, the likelihood of it being the disk itself is pretty low.
Is this an external drive, powered by USB, or an internal drive?
NShameA
#3 Post by NShameA » Fri Mar 11, 2016 8:03 pm
Hello, ty for responding....internal.
Manufacturer: MATSHITA
Product: BD-MLT UJ267AM
Revision: 1000
#4 Post by Woodstock » Fri Mar 11, 2016 10:04 pm
OK, that drive is a laptop "internal USB" drive, and can have trouble with power if the laptop isn't plugged in and charging. Everything will be fine until the read speed starts to climb.
Right now, there is no speed limit setting in MakeMKV - it's going to request data as fast as the drive is willing to give it. The error you saw about the "TRACK FOLLOWING ERROR" may be the trigger... Spinning disk uses up available power, then the head needs to move. Electronics reset because of voltage drop. While it is resetting, you get I/O errors.
Again, this is just the most likely scenario - try ripping the disk again. If the error happens very close to the same offset, then we're looking at a disk error, rather than a drive error.
NShameA
#5 Post by NShameA » Fri Mar 11, 2016 10:24 pm
Hello again, thank you so much for your comprehensive answer. In the meantime I had ripped the disk using my external Pioneer BDR-209M in Bytecc case (plugged in to wall). Error results below. Im not positive the offsets are close, I don't understand the size relation for offsets...
Error 'Scsi error - MEDIUM ERROR:1185' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '8990294016'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom5' at offset '8990294016'
Error 'Scsi error - MEDIUM ERROR:1185' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '8990552064'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom5' at offset '8990552064'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom5' at offset '8990556160'
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.20
Again Thank You
David
