Attempting to back up Bridge of Spies, marked with 'B' on disc in Australia.
Message pops up:
'BD+ code processed but no FUTs were obtained, errors may follow'
Playback of the movie file was blocky.
Disc Id:
294DA017C6DB95FA170AE54EA3B1A39C45C2DD0F
MakeMKV v1.9.9 win(x86-release) started
Backing up disc into folder "J:/Video/backup/Bridge of Spies"
Evaluation version, 25 day(s) out of 30 remaining
Loaded 25 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
...then the above message pops up...
Bridge of Spies (Australia) no FUTs were obtained...
jeterley
Re: Bridge of Spies (Australia) no FUTs were obtained...
When that message popped up, it should have included a link to click on to send the necessary information to Mike to create the proper SVQ file. You should also have a file in your MakeMKV data directory that contains that information, which can be emailed to svq@makemkv.com for analysis.
jeterley
There is no message. There is a dump file which might contain what is referred to in:
/faq/item/8
/faq/item/8
Well, actually, that would be the dump file referred to here: /svq/
It needs to be emailed to svq@makemkv.com . If your email system won't allow you to send a file that large, you would need to upload it to a site like "dropbox" and send the link to the file instead of the file itself.
dxer#
Hi, i get same error and have emailed dump file link , any thoughts ?
cheers
cheers
dxer#
right, lets see ..... im guessing thats a no then
Not much to think about... When Mike gets the SVQ file generated, it's put on the server for MakeMKV to pick up when you next try ripping the disk.
In the years I've been on this board, I have never seen an announcement from him about a new SVQ file being created.
dxer#
ok understood Woodstock, and thankyou.
